Full Version: Clutch Bleeding
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Engine & Transmission
billybandit
does any body know how to bleed the clutch up on the is200,
Chris.S
Why do you need to bleed it ?
billybandit
i've just fitted my supercharger, and i've had to mod the clutch header tank to get my new airbox in.
TonyGoose
QUOTE(billybandit @ Aug 18 2003, 08:11 PM)
The clutch reservoir should be removed - tee's into brakes instead.
Clutch bleed is on pass side of gearbox ...
About level with where front wheelarch meets sill.
Monster-Mat
yes....you should get an adapter to go on the clutch cylinder, where the reservoir used to be, this is then connected to the brake reservoir
billybandit
