latintxn
Aug 20 2003, 04:10 PM
Recently my '97 LS400 started displaying the "Rear Light Failure Warning Light".
After checking EVERY bulb & insuring there were no burnt bulbs the light still displays continueously.
One obvious difference that I've noticed is that everytime when I first start the car up, no problem. But as soon as I press the brake pedal and shift from PARK to REVERSE, the light displays.
Can anyone shed some light? (No pun intended)
Thanks from Houston, Texas!
ColinBarber
Aug 20 2003, 08:08 PM
I think the system can only check the brake circuit once you press the brake pedal so not seeing the warning light when first starting up makes sense.
I would recommend removing the bulbs and clean the terminals and check for corrosion in the bulb holder.
james2210
Aug 20 2003, 09:28 PM
Have you had someone stand behind the car and physically check the lights come on? Also, are all the wattages correct?
click here.
