QUOTE(oka97 @ Sep 3 2003, 03:19 PM)
Alas, us ordinary folk don't have a clue..
Tell us some good uprated clutches!
I assume you can ask a garage to order the part and put it in for you?
Ok, there are loads of Uprated clutches available.... most performance outlets stock them (EBC, Helix etc...) but I doubt your local dealer would fit it for you.
Some different types available from Helix:
HEAVY DUTY COVER ASSEMBLY
The Helix clutch is intended for applications where the engine / vehicle performance has been increased above standard. All Helix Racing Clutches are manufactured from new components to the highest standards using the best materials available, they are designed to give a higher clamp load to cope with the higher torque capacity together with an increase engine rpm. The units can be fitted as a direct replacement for the standard unit without modification to the flywheel and retaining the standard clutch release mechanism. There are a few exceptions and these are identified in the catalogue.
DRIVE PLATE ORGANIC SPRUNG CENTRE
This type of drive plate is suitable for road use and light competition work. The design features damper springs arranged radially around the hub centre which together with facing segments provides progressive engagement and greater degree of clutch control. The organic facing material used is the best high performance material available with facings over 200mm diameter being metal backed to give a much higher burst strength.
DRIVE PLATE ORGANIC RIGID CENTRE
The rigid type of drive plate is not fitted with any form of damper cushioning and is specifically designed for more arduous conditions where the degree of comfort / refinement is second to durability and strength. Again only the best high performance organic friction facing material is used.
DRIVE PLATE CERAMETALLIC SPRUNG CENTRE
This type of drive plate is more suitable for high energy competition applications like rallying although it can be used for road use where the organic drive plate cannot withstand the higher operating temperatures. The design incorporates a sprung centre to provide some protection against drive line shock . Manufactured with a rigid adaptor plate ( instead of cushion segments ) incorporating cerametallic pads as shown. This cerametallic material keeps its friction properties to a much higher temperature than the organic material.
DRIVE PLATE CERAMETALLIC RIGID CENTRE
The rigid cerametallic drive plate has no form of damper or segment cushioning and is designed primarily for the most arduous of working conditions where strength and durability are paramount with the heat resistant properties of the cerametallic friction pads.
