j88chn
Aug 28 2003, 06:23 PM
Wonder if you chaps can help here? I have a MkII '93, so far so good - rides beautifully and handles quite well (even my S-class pal thought the ride was better than his). When the engine is running and the vehicle is stationary, I find that I cannot open the boot from inside the car. The only way I can open it is to switch off the engine then pull the boot release. Is it just my car or does all the early models do this?
james2210
Aug 28 2003, 07:37 PM
Have you tried with the gear lever in the P position?
Jason 92 Mk1 LS400
Aug 28 2003, 08:22 PM
I have exactly the same problem...most annoying
Jusy like when you unlock the car with the remote, open the back door and spend 30 seconds fastening my daughter in the baby seat - then try to open the drivers door but it has locked itself.
It got really worse, about 2 weeks after buying the car I did this and left my keys on the back seat - My daughter thought this was really funny - learning a new "how to open the car door for daddy trick"
The worst 30 minutes I have ever spent in Asda car park
Paulrwales
Aug 28 2003, 09:20 PM
We can only open the boot lid from the switch when the engine is switched off and gear lever is in Park position, also our car locks itself if nothing happens after unlock for about 20 seconds or so, got to be extra careful not to lock the keys in the car!
Paul
Paulrwales
Aug 28 2003, 09:22 PM
Talking about locking the keys in myself , not you Jason!
j88chn
Aug 28 2003, 10:04 PM
I have got around the car locking by itself problem by installing an alarm and immobiliser in the car which unlocks/lock/arm/disarms the car. If I go back to using the button on the lexus key then the car will do the old trick. I have also found that as the alarm/immoilizer is connected to the footwell light, when one tries to open the armed and locked drivers door, the alarm goes off. I was impressed. However, this does not settle the problem We are facing with the boot mechanism vis-a-vis engine on/off. Will speak to an electrical engineer I know to see if he can get around the circuitry and make this baby pop.
flotsam
Aug 28 2003, 11:13 PM
The dealer when I bought my MkIV said the automatic re-locking of the doors occured only if none of the doors were opened as a security feature.
I haven 't tried opening one of the back doors and seeing if the whole thing locks or not. I'll have to try the remote opening of the boot with the gear in neutral as well.
93_LS400
Sep 1 2003, 04:06 PM
One will say - me too on this ; switch won't work with engine on ... must be a safety interlock ...
the doors locking on their own is dodgy... does it do that if you leave the key in [ I haven't tested it on mine yet ] (driving a 93 model here )
flotsam
Sep 1 2003, 05:44 PM
No it doesn't do that if you leave the key in as you must have opened the doors therefore won't lock.
click here.
