Full Version: Lowering Springs
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 430 / Lexus 450h / Lexus GS 460 > Brakes & Suspension
jac114
I have been thinking about it for a while now.. what sort of springs should I look for.. And if fitting them myself is there anything I need to know..
Also where can I get them from do we get gold from somewhere?
jac
Scorpion
jac114,have you done this before?
some struts you can drop straight out,not sure on yours
if you need a set of spring clamps,i have a set you can borrow.
Anyway, once strut is off just clamp springs,undo top mount and release spring
replace new spring, reconnect shock to top strut,bolt up bottom.....job done
dont forget the pics
Monster-Mat
Craig id suggest if you have never changed springs and dont feel 100% confident doing it, to pay some one to do it, if done wrong you could sriously injure yourself in the process
Scorpion
Piece of cake with the right tools(clamps)
Fidgits
Can you get Eibachs for your car Craig?? there probably the best ones to get..
And you know my feelings on this.. I wouldn't even consdier it..
Scorpion
WHY NOT?
wildrnes
i recon you could do it jac
make sure you plan it out thoroughly
oh by the way figits when do you want me to change that lightbulb for you ..... blink.gif
jac114
o.k now where would i go to get a set??? is there anybody in the gold forum?
jac
Monster-Mat
a few companies in gold, sell springs and stuff
Fidgits
QUOTE(pee.j @ Aug 30 2003, 09:28 AM)
WHY NOT?
a. I'm mechanically inept
b. I'm mechanically inept
c. I'm just not prepared to play around with any 'major' mechanicals on my car because:
d. I'm mechanically inept
e. If i messed it up, I'd be in big trouble
Did I mention I'm mechanically inept?
jac114
well i think i could do most things.. although i dont think i would touch anything major on the engine..in saying that i am not sure if i would risk changing the spark plugs due to there location
jac
BESTY
let me know if and when you change em,i`m thinking about it so tell me what difference they make smile.gif
Fidgits
Jac has a GS... your better asking Wildrnes/zee etc.. they have done it to an IS..
phunt
Ive just done mine today.took me from 10:30am till about 6pm.I used PI springs which i got off a dealer on the gold forums once youve done one side the other side takes half the time because you know wat your doing the second time round,pretty basic job really,but the struts can be a bit ov a pain to wangle out past the hubs.if i was going to do it again ide remove as much of the hub asseblies as i could because it woudlve saved me quite a bit if time.oh and make sure youve got sum1 to help you,its deffo a 2 man job.the car doesnt seemed to have dropped as much as i would like but from past experiance it takes at least a week just to bed down,cant really notice any change in the comfort but handeling is deffo imroved.all in all a cheap and very affective mod,should be done to all IS's.i also fitted mt Peco BB4 today and im not very impressed yet but like the springs they also take a few weeks to get carboned up and just get better and better.Hope this helps smile.gif
BESTY
QUOTE(phunt @ Aug 31 2003, 01:10 AM)
Zee007
Go for Eibachs - you can't go wrong. And Craig, TTE do lowering springs for yours too mate........ wink.gif
phunt
QUOTE(Zee007 @ Aug 31 2003, 04:56 PM)
Well like i sed i used the Pi's and the comfort level feels exactly the same,and they are prolly the cheapest ov the springs available and im not sure but i think Pi's go the lowest.....well they deffo go lower than eibachs anyway wink.gif
Zee007
QUOTE(phunt @ Aug 31 2003, 05:27 PM)
Spax, Eibach, PI, H&R, TTE, TRD, HKS all do springs for the IS........ Each has different levels of comfort and drops......... smile.gif
Loz
DO Pi do springs for the GS. I thought it was only Eibachs that did, and even TTE use them. they are the standard fit on the sport GS.
phunt
I thought the sport was anly 15mm lower but eibachs are 30mm?
Loz
maybe Eibach make two types? Maybe Gary C has the aftermarket type which would explain his crashing and harsh ride....
just a thought...
ColinBarber
The TTE springs for the IS and GS are re-badged Eibachs and lower by 30mm.
The GS Sport is lowered by 25mm. I don't know if they use the same springs? Maybe the shocks are also different on the sport which is why the drop is not 30mm?
The IS300 is 15mm lower than the IS200.
The new GS sport (July 2003) is 20mm lower than the standard GS.
I installed the Eibachs on my GS300. It improved body roll and the car looked better but crashed over bumps (slightly more than the stock ones). It always felt that the springs didn't suit the shocks.
