QUOTE
Does anyone know what type of oil is best for the gearbox and diff on an IS200 Sport? Semi Synthetic or Synthetic? Is it the same for oil for both gearbox & diff or different?
I've used Castrol Syntrax in my previous car (Impreza Turbo) and found it very good. Would this be OK for the IS200?
Cheers
Gavin
This is what the manual says...
Manual transmission:
Oil capacity = 1.9L (2.0 qt., 1.7Imp.qt.)
Oil type = Multipurpose gear oil API GL-4 or GL-5
Recommended oil viscosity = SAE 75W-90
Differential:
Oil type = Hypoid gear oil API GL-5
Oil viscosity = SAE 90 (above -18deg.) SAE 80W or SAE 80W-90 (below -18deg.)
The service manual makes no mention of changing the gearbox oil (though it should be inspected every 4 years / 40,000 miles).
The differential oil should be replaced every 20,000 miles / 2 years. I was told by the dealer that they used Castrol Syntrax SAE 75W-90. This doesn't quite match up with the specification in the manual but, since I couldn't find anything that did match exactly, it's what I used.
Be aware that the differential takes approximately 1100ml of oil so if you buy it in 1 litre bottles you will need two.
