Full Version: New Happy Windom Owner
Lexus Owners Club > Lexus Models > Lexus Imports > ES300/Windom
SKT174
Hi .. I just got my Windom yesterday biggrin.gif and I'm very happy with it. It's a 93 model, it's done 152000kms but the condition was excellent. However I do have a few small questions.
1) You know when u turn the key to On position (just before starting the car) there are a few warning lights comes on, there is one on the bottom left which looks like a car with lights at the back (it's yellowish orange color), anyone able to tell me what does it stands for?
2) Does Windom comes with ABS or not?
Most appreciated
ColinBarber
1/ Car with lights at the back sounds like the rear bulb failure light. Don't know if it's just brake light or tail light as well.
Steve
the orange light is bulb failiure.. this usually comes on becasue you probably have had a fog light conversion.. if your fog light comes on inside the rear light then the orange light is normal and you should forget about it
Yes windoms come with ABS... when you first turn the ignition on the ABS light will show for a few seconds
and if you have the fully loaded version then you will have traction control, Electronic modulated suspension and loads of other goodies!
have fun.. i had one for 3 years and was a very reliable motor!
mooreboy61
I just had this problem and used your discussion to diagnos and fix it. It was a burned out rear bulb. Thanks for the help!
