Full Version: Total Electric Shutdown
Lexus Owners Club > Lexus Models > LS 400 / Lexus 430 / Lexus LS460 / Lexus 600h
alanuk400
My 92 LS400 Has suddenly developed these symptoms. On taking out the key after driving the steering wheel didn't retract in, so I put the key back in, no dash,gearlever,rear lights. The only lights are headlights,no indicators,reversing or breaklights.Car started & drove, power steering was heavy, no central locking. If I try anything I can here a slight clicking.
Can anyone help
Alan
Steve
have you changed any fuses lately.. if so were they the correct ampage?
I saw something similar to someone who had placed the wrong fuse.. car went all haywire.. weird
flotsam
Impossible to say for sure without having a look but if it was all ok whilst the engine was running and then immediately stopped working when the engine stopped, that probably means you were running off the alternator alone and the battery was flat and not being charged by the alternator.
alanuk400
I went back out & tried it after about 1 hour, everything was ok.The same thing happened again tonight. At the weekend I had fitted a reversing aid from Argos £30, that is wired through one of the reversing lights, I unpluged it after the second time but is was still the same. The only thing is working is the front & interior lights.
Alan
alanuk400
I think I have found the problem, a large white square 120 amp fuse in the main fusebox had been broken & the wires were just touching. I can't get it out of the holder, should it just pull up or do all four come out as a unit.
nickmoul
Unless one of the Club's electric ghuru's are online, I suggest a call to your local Lexus Garage is worth a try. Also a query to LOC US should produce some replies as they are on Thanksgiving weekend and I bet there are loads of bored LS400 owners online.
As far removing the fuse, it might be that its got itself welded in there - 120 amps is a big load and anything thats "broken" it musy be very close to a dead short. Suggest gentle persuasion and best of luck!
Nick
flotsam
QUOTE(alanuk400 @ Nov 29 2003, 03:07 PM)
There should be a fuse extractor amongst the fuses. Mine's in the engine bay fuse box. They just pull out.
Before replacing the fuse, find out why it blew in the first place.
ColinBarber
QUOTE(flotsam @ Nov 30 2003, 02:46 AM)
I don't think those little fuses extractors are meant for the big fuses. I would remove the battery, then the fuse and check the resistance of the circuit to make sure you don't have a short.
If the fuse only has a crack in it rather than the link completly blown then there may not be a problem.
alanuk400
Yes, it only had a crack in it, it has been like that from when I bought the car. I will pull it with a pair of long nose pliers. The cold weather must have something to do with it, the bonnet landed on my head so I need struts, I know that on the US site there is a cheap way of getting them, does anyone know of a cheap supplier in the UK
Alan
alanuk400
I have changed the fuse ,it is a long job. The spades of the fuse are about 4" long, there are 2 8mm bolts holding it in which are hard to access, you have to unbolt the fusebox it'self & take plastic covers off .
Alan
benfur
QUOTE(alanuk400 @ Nov 29 2003, 04:07 PM) *
Hi Alan
Dont know if you are still a member!
But a big Thank you for your listing
Just bought an LS400 with Exactly the same electrical problems.
After reading your experiences , located the 120 amp fuse and replaced,
Everything working fine now
I dont know if it's a coincidence but the car is also fitted with after market reversing sensors [ genuine Toyota ]
Many Thanks
Benfur
