Full Version: Headlight Eyelids Installation
Lexus Owners Club > General Lexus Forums > Lexus Work Shop (Submit your Tip!)
yemgi
BESTY
good pica yemgi,off topic but did you post your carbon ok
SteveAudioX
I must say those carbon ones look good with your bonnet..
I still have mine and really thinking about it...
I guess i'll have to try it and see....
jdmparts_guru
Carbon Fiber eyelids are more difficult to install then fiberglass eyelids, since the fiberglass material is much softer/flexible.
yemgi
yes, you better use whindshield black glue for sticking them
Gus
thanks yemgi, great guide.
Thoose of you that got the fiberglass ones, have you used windshield glue ?
I will try to get mine painted and fitted this month.
Scorpion
Clear silicone worked for me,blasting up the M/Way@ over speed limit they're still on there whistling.gif
Gus
hmm ok
i got theese with the eyelids
but i dont think they would do the job
Scorpion
I wouldn't use it,the tape is very thin and i just dont think it would be up to the job.
If you use windscreen glue and you want to change your car,and remove the eyelids it is a real pig to get off the lense.
Maz
so what to use best Pete? i dont want to loose my eyelids again.......... cry.gif cry.gif cry.gif
Scorpion
Follow the instructions above,but i used silicone and taped them down for about 5 hours(let silicone dry right out)works a treat Mz.
Maz
QUOTE(Scorpion @ Mar 6 2004, 03:32 PM)
Thank Pete, i will try and remember to let everything dry out this times......... whistling.gif whistling.gif whistling.gif laugh.gif laugh.gif laugh.gif
whitie
One of my eyelids was coming off so, I've taken off the tape and stuck them back on with silicone. Now they don't seem to be touching everywhere.
I've just masking taped over the top, but when I push down on them they push down a few mm to touch the headlight..... Will they stay on when dry unsure.gif ???
Steve
double backing tape is not that thin.. i used it on my soarer and at high speeds, very wet snowey weather they stuck on like poo poo to a blanket
whitie
The answer is no it won't keep on, so got some tape from a mate whos into sailing, tape which they use for hull repair, or something like that?
yemgi
mines are taped for the mo cause the weather doesn't allow me to glue them as the car stays outside. They are on since november and I have no probs even at 200km/h . As Pete said, windshield glue will be nearly impossible to remove without destroying the glass. The silicone is the best if you want to sell your car back to the original look.
Maz
what kind of silicone should i use, will i able to get them like from Halford?
Bazza
QUOTE(Maz @ Mar 30 2004, 11:15 PM)
B & Q is your best bet
Maz
tried fitting my Tom eyelids today, but the double side tape not strong enough as the eyelids need to be pressed down at both end to fit properly, so i think im going to get some silicone as well as double side tape, but what the best double side tape i can get?
also which type of silicone should i use, as there are many different type i can get from B&Q, and i think most of them are soft rubber type....
jdmparts_guru
The best double-sided tape is the red 3M tape.
It is used in bodyshops, etc...
Maz
where can i get some 3m tapes?
Lexus Jim
just use some good mould resistant clear silicone. It would be cheaper to get it from your local plumpers merchant than B&Q tho. I'll be putting mine on next week just with silicone
Lexus Jim
I couldn't find out any info by searching so was wondering what you guys with black IS's and black toms eyebrows did with the grey outer rim around the headlights that can be seen slightly (but not as clearly) here along the top far edge of the eyebrow where the wing comes over:
was thinking of spraying them black or have you just left it. it looks really obvious on mine
DUNCAN
Guy's,
Remember to make sure your headlights are very clean before you stick them on. I used methylated spirits on mine and have had no problems at all. (stuck down with double sided foam tape)
aido
OT but where's your car gone Duncan?
