Full Version: Remote Re-programnming On Gs
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 430 / Lexus 450h / Lexus GS 460
greve
In the General Maintenance section, there is a thread which gives a procedure to re-program the remotes used for an IS 200 (see this thread).
Does anyone know how to do this on a GS?
Scorpion
Colin one for you mate!!
ColinBarber
Do you have a separate remote on the series I or is it built into the key?
mudzs
It is a seperate remote colin
jac114
Question.. what is this seperate remote thing Mudz.. are we talking central looking here? as mine is
all in the key??
craig
mudzs
Mine looks like this jac http://www.lexusownersclub.com/gallery/Mis.../key_and_remote
greve
Mine looks exactly the same as mudzs's. And it's more than remote locking as the alarm most definitely goes off if I try to open the boot before de-activating the alarm via the remote blush.gif
ColinBarber
I'm not sure if you can program a new remote. A dealer may be able to order a new remote which will work as they may have records based on your chassis number. Otherwise a new receiver unit and remotes will be required which will be expensive although fitting shouldn't be too expensive and all the wiring is already in place.
It may be worth you speaking with your local dealer or Chris Shipley to find out your options.
jac114
QUOTE(mudzs @ Dec 12 2003, 10:11 PM)
http://www.lexusownersclub.com/gallery/alb..._0374.sized.jpg
Mine does not look the same.. Mines built in
jac
mudzs
How strange must have changed them on the 96 models cant think why though as i much prefer it built into key,
ColinBarber
I think the old system (with lock built into the key) is not CAT1 compliant (if it has an alarm and not just remote locking?).
From Dec. 95 the GS alarm was CAT 1. Probably installed once the vehicle comes into the UK
