Full Version: Removal Of Drivers Side Door Panel.
Lexus Owners Club > Lexus Models > RX300 / RX400h
john graydon
Hi
Could anyone tell me how to remove drivers side front door Panel. Got as far as getting the screws under panel and side plastic rivets out and also screw out at door opening handel. Panel wont come apart because of electric window switches,dont want to force it. Need to get to speaker in door as it wont work and tweeter on window sill not working either all speakers work fine in car. tried volume & position levels on screen but still wont work.
Scorpion
If its the same or similar to the IS,use a trim tool or something flat to lift the control panel up !!
john graydon
Still couldnt remove the door panel, there seems to be something holding the door handle. I Got the wire going to the speaker and wired it up to another speaker that works and it doesnt seem to be the speaker thats faulty. The mus be a connection from the radio. How on earth do you get into the back of the radio. What panels do you remove to get anywhere near it. Afraid of damage to the wood surround if I do it the wrong way. Any Ideas???????????
