Posts
1,594 -
Joined
Last visited
Days Won
12
Content Type
Profiles
Forums
Events
Store
Gallery
Tutorials
Lexus Owners Club
Gold Membership Discounts
Lexus Owners Club Video
News & Articles
Everything posted by johnatg
I've looked at the manual / procedure a bit more carefully - I think the work is done by removing the rear bench seat. There's a 'partition pad' under the seat and below that a cover in the floor to be removed. Then the vent tube assembly is held into the tank with a retaining ring which is removed with a SST. I rather think it is the retaining ring which they are calling a flange which may crack. If it did the vent tube assembly wouldn't be held into the fuel tank properly (tightly enough) So you can leave your stuff in the boot!
Seems pretty expensive to me. It is 6+ years old - i paid just a bit more for my (premier) car at 5- years old and less than half the mileage of this. Second hand car prices really have rocketed but I think they are on the way down now. Was obviously a motorway cruiser for the first 3 years (to 87K miles) but hasn't done many miles for the last 4 years (but then neither has mine) I don't think GS300h shocks will be any less than GS450h - I suspect they use the same shocks, even though the front of the 450h will be a bit heavier (maybe). Note that it has AVS (Adaptive variable suspension) which is what really puts the shock price up. You need quite a bit off this price - but good luck with that - Lexus dealers aren't very negotiable.
They made that up. The recall is for the flange which the vent pipe is connected to - it can potentially crack (stress fracture). It's metal, of course. The actual vent pipe is not affected. See my post re GS300h recall for pics of the item. They are only starting the work in February and it seems as if most Lexus models around particular dates are affected so they are going to be swamped. They (Lexus Stockport) moved my appointment from February to March due to pressure of number of bookings for the job.
RC F - Fuel Vent tube recall.
johnatg replied to RadicalCoupe-Fuji's topic in Lexus F Club - Lexus IS-F / GS-F / RC-F Club
Which means you can look on the Mot check site. Outstanding recalls are listed there. -
I received one too - for my GS300h. I've posted a pic of the removal procedure on the GS300 etc forum. It's pretty easily accessible under the boot floor - I think it shouldn't take more than 1/2 hour and you get a free vehicle health check too. I'm booked in at Lexus Stockport for March 20th. It's for a potential crack in the flange where the vent tube attaches to the tank. I suppose if your car is affected, it's urgent. But probably it isn't (affected or urgent). They're starting the job in mid-Feb when I guess they hope parts will be available. They did book me in for Feb but now they've moved it to March. -
I've received a recall letter from Lexus this morning. It refers to the 'Fuel tank vent tube assembly', which is attached to the fuel tank by a flange. This flange can potentially develop a stress-related crack which could lead to the possibility of a fuel leak and a potential fire. So they're replacing the flange. For your interest, pic of the relevant part from the removal procedure attached. I guess it's the big circular thing which is removed from the tank with the SST. I don't know what production dates are involved - only that mine is affected. I'm not using the car much at the moment, so I'll need to wait a bit until my fuel level is down - they want it presented with less than 1/4 tank
I don't think you need to replace it (not sure what it is). Just take it off, give it a good wire brushing and paint it with some anti-corrosion paint (can you get Hammerite there?) Spray the bolts with some wax (I'd use Waxoyl here in UK). Make sure there's no paint on the earth points, but spray the general area of the earths after you've reassembled.
Welcome to the forum, Steve. Throwing parts at this is going to be very expensive - you really need proper diagnosis. Are any fault codes registered? They should be stored, even if things seem to have reverted to normal. You should be able to purchase a low cost fault code reader (connecting to the OBD11 port) which will show faults on your smart phone. Be careful with interpretation of fault codes though - often the actual fault may not be what the code first indicates. The symptoms point to a sensor failing - they often fail gradually, starting only when they get hot and then eventually causing problems at lower and lower temperatures. Maybe the camshaft or crankshaft position sensors. The oil control valve is another possibility. Problems with these things may only show up under failure conditions and you may need to have an oscilloscope used to analyse the signals. I appreciate that may be difficult in your location and even more so if you are on a long trip. Get back to us if you can identify any fault codes. Good luck!
I'd check the earth connections for the headlights, particularly the right hand one. When a light flashes when it shouldn't but in sympathy with another one, it is almost always due to a poor earth. eg you often see brake lights flashing with indicators - it's because the indicators are earthing through the brake lights. I think your situation might be similar. I'm afraid I can't help with where the connections are and I don't have a wiring diagram showing DRLs - my IS250 was a 2005 model and my workshop manual is a bit old.
I reckon you've been charged for someone else's fuel. £1.89 is about right for v-power diesel. I guess you would have paid about £1.60 for v-power petrol but you got E10. I always triple check - I ask myself is this petrol? Is it the green handle pump? Is it E5? (I always use E5) And note the pump number. It's easy to do the whole thing on autopilot! And get it wrong! Have a sniff in the fuel filler - you will be able to tell if it's diesel.
Welcome to the OC and forum - although it would be better if you posted on the RX450h forum (I know the title of this forum includes 'Lexus 450h', but it really means GS450h) The courtesy delay for the headlamps will most likely be a Techstream setting. There are quite a few of those and the dealer should do it free of charge once. I'd ask for a list of them from the dealer and ask them to change your settings. They may be in your handbook. (One I'd advise is the facility to open the windows from the remote - if set, you may find the windows open when you come out on a wet morning! It can be unset!) After that, you need to pay or get your own Techstream (available on eBay) But the RX450h guys may know better (and more)
I've found a workshop manual, including wiring diagrams, service information - everything you need for Gen4 GS maintenance and repair. It's available here: www.servicemanualbit.com/downloads/lexus-gs300h-gs450h-awl1-gwl1-service-repair-manual-ewd-2015-and-later/ It costs $30 (about £26 today) and it comes as a .rar file download. You have to extract it with a suitable app, eg WINrar. It only works in Internet Explorer and you have to have Javascript enabled. That's not that easy but with a bit of trial and error I got it working. Been browsing all afternoon - how to waste your day! 🙂 I think the '2015 and later' refers to USA - ie 2014 to us in UK. But I'm sure it is applicable to all Gen4 models, despite some differences between 2012-2014 for GS450h and after facelift. I know that it's often repeated here that there isn't one available, so hope that helps!
VSC Sign
johnatg replied to nislam16's topic in Lexus IS 250 / Lexus IS 250C Club / Lexus IS 220D & IS 200D Club
Before changing sensors, check the wiring looms to them very carefully and check the engine and battery connections and earths. Too many faults there for sensors to be the real cause - there will be something central and simple causing all the DTCs -
I think my full tank range is about 500 miles. I rarely run it down to close to empty - I usually fill up when it gets to half way - get a full tank before the next price rise! Maybe I should run it lower, now that prices are falling (for now). Actually, there's not much that Joe's Motors (or diy) can't fix. Maybe not the Hybrid drive bit (inverter and traction battery) but they don't need finger-poking anyway. The rest of the car is conventional - you just need to be aware of a few things (eg don't open the driver's door with a brake bleed nipple open). I look after my own GS300h - no-one else gets to touch it! (except for specialised things like tyre changing and wheel alignment) I highly recommend watching the youtube videos by 'Car Care Nut' - he's a Toyota/Lexus Master Technician but he tells you the truth - when to use Lexus stuff, when to use aftermarket, when you can ignore Lexus service schedules (eg only even think about changing spark plugs after 120K miles) and things you must do religously - (eg change the oil every 5K miles)
Was the 2012 a Gen3 GS450h? The 2016 is Gen4. There were quite a few spec changes. The 6 speed vs 8 speed thing is a bit of a red herring. They are artificial ratios, not real gearbox ratios. As Shapoor said, these cars have E-CVT gearboxes, with constantly variable gear ratios. It has, in effect, an infinite number of gear ratios. Electric motors are used to control the speed of the planetary gears. The 6/8 speed thing is an artificial set of ratios to give the feeling of 'changing gear'. It is achieved by using said electric motors . You can change between the ratios with the paddles - temporarily. But within a few seconds the gearbox controller takes over and reverts to the ratio the computer thinks best. Handy for overtaking though. E-CVT gearbox controllers monitor the driver's behaviour. It may be that the chap you bought the car from drove it gently. If you hoon around for a few hundred miles/kilometers it might well start to feel different!
Spark Plugs
johnatg replied to westo3's topic in Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
I guess that is an issue that it would be wise to check. -
Spark Plugs
It's not fixed price re spark plugs. They charge considerably less if you don't get the plugs changed - something like £200. I think they base the price on the GS450h price - that's 6 plugs and a much more complex job vs GS300h with 4 plugs and no access problem. Something like 90 minutes vs 20 minutes. They want to do it at 60K mile service even if the car has done much fewer miles. I told them not to do it at 42K miles and 6 years - now the car is 8 years old on 50K miles. I'll be waiting for quite some time yet. As Colin indicated - they'll most likely be OK to 100K miles.
