Posts
2,597 -
Joined
Last visited
Days Won
13
Content Type
Profiles
Forums
Events
Store
Gallery
Tutorials
Lexus Owners Club
Gold Membership Discounts
Lexus Owners Club Video
News & Articles
Everything posted by Shahpor
Lexus IS 250 Illuminated Blue Logo Door Sills not working
Shahpor replied to Slucky's topic in New Members Area
Hey, It would probably be a case of removing and check the scuff plate itself then. They just clip on, but can still be tricky to remove. Once off, you can check them like so: -
is220d SE Airbag Recall
Shahpor replied to acer54's topic in Lexus IS 250 / Lexus IS 250C Club / Lexus IS 220D & IS 200D Club
Welcome Jason. Funnily enough, my car is also going back to Lexus Reading in a couple of week for a noise from the dash since the air bag recall was done. The difference is, it will be the 3rd time it has gone back! Fair play to the dealer though, they have never questioned it and have always had another go with no fuss. I would struggle to connect a faulty headlight with the dash removal to be honest. It could just be bad timing. I could very well be wrong, but I would have thought it is much more likely to be a problem with the light itself. -
Well, I can only speak from personal experience, but mine always starts easily regardless of the weather. Although, I will admit being down south probably means i haven't started mine in the cold temperatures you guys have experienced. Assuming it is not normal (it might be fine), then it sounds like it is turning over ok, so more likely something like glow plugs or fueling.
Why do I get the feeling I am being sucked into something here? Am I anti horse if one is on the road at peak times holding everyone up? Yes, I am. And it is not about how much time it added to my journey, but the cumulative affect it has on all concerned. 1 or 2 minutes for me, 1 or 2 minutes for the 50 cars travelling the same road as me, 1 or 2 minutes for the thousands more each day that come across the same thing. Personally, I don't think an attitude change is necessary; what is necessary are bicycle lanes. I'm sorry, but this sounds like back pedalling (if you will excuse the pun). Again, I will say that I could be mistaken, but that it not how your post came across, and it seems I am not the only one who thinks that.
Parking fine
Shahpor replied to jackcramerr's topic in Lexus IS 250 / Lexus IS 250C Club / Lexus IS 220D & IS 200D Club
Seriously, you have never had a parking ticket before? It can be a tricky one because, if you look at it from the councils perspective, they must get people trying to make excuses all day. Although, in this case, I do think it is unfair to you. Unfortunately, unless you have a picture of the car parked with leaves covering everything, there is not much you can do. You also say there were no signs, but there must be one somewhere close? You say you argued with the council, so assuming you have already told them all this, then looks like you have to pay up. -
@doog442 so what is wrong with being anti cyclist? I am not against people riding bikes per se, but there have been times when I have had to endure a long tailback on a single country road because of a cyclist, when I wished they were off the road. Also, as far as Linas wanting to punch them, he was referring to one specific instance, and again, I can relate. I can't seem to see where he says they are retarded, although I will admit that he does like to type long posts so I may have missed it. You also state that you think cycling isn't dangerous. Have you seen what it is like for them on London roads? If you did, you wouldn't say that. Since the roads are so narrow, cars, and especially vans/trucks, don't leave much room so it easy for them to get squeezed. If you watch the episode of Top Gear when Richard Hammond racers the others on a bike, you will see what it's like. Although you need to watch the outtakes to get a real sense since he swears so much! Anyway, the point is that while Linas can be grating (there's always one ), he still doesn't deserve what you wrote. You could always be the bigger man and just leave this be.
Welcome Paul. I am afraid I can't help you with the noise as I can't seem to open the files? You could try attaching them to a post on here? As far as the gear stick goes, yes, it is tilted towards the driver. It is a little strange, isn't it? I don't think smelling fuel is normal and I am pretty certain mine doesn't produce any smells when stationary or moving slowly. The obvious answer would be a fuel leak somewhere. What is your mpg like?
Fuel Ripoff
Shahpor replied to madasahatter's topic in Lexus IS 250 / Lexus IS 250C Club / Lexus IS 220D & IS 200D Club
I am the other way round since I have only run my car on Shell V Power, so I am not sure whether to switch to standard diesel since it could undo any benefits I might have gained up till now. I was tempted to switch today though when I filled up and saw it was 135.9p a litre! -
No, it is a 15A fuse. These PDF's should give you an idea where it is: CSJB-RH.pdf EngineR-R.pdf Just pop the cover off the fuse box and pull the fuse out. It should be obvious if it has blown or not. As for the OBD2 port, do you mean the DLC3 connector here: I have absolutely no clue when it comes to these diagrams, so perhaps you can tell me why you checked for voltage across that pin? Thanks.
G Spider wheels
Shahpor replied to is200 Newbie's topic in Lexus IS 250 / Lexus IS 250C Club / Lexus IS 220D & IS 200D Club
Well, it seems you did get a bargain considering how much they want for them now: As you can see, this price is without tyres. -
According to the manual you should check the following fuse first: Remove the AM2 fuse from the cowl side J/B RH. Measure the resistance of the fuse. Standard resistance: Below 1 Ω After that, it recommends removing and check the switch, which unfortunately requires removal of the sat nav/stereo unit.
G Spider wheels
How did you manage to score such a bargain? I can't be sure, but this video looks like the right colour and wheels: https://www.youtube.com/watch?v=dF3drybTBaI -
Nice looking car you got there What spec is it? How was it mapped and what is it like now?
Nice looking car you got there. Don't see many in black. Sorry, I should have mentioned that I posted the video only to show you how to change the light, not the purchase it from them. I assume if you get OEM lights then you won't have a problem with AFS, although I would think that the satellite function won't work. Might be worth looking for someone who is breaking a facelift car.
