Help With Fitting Parrot System To My Gs300
Right guys having a bit of a night mare trying to fit a parrot system to my gs300 it's one with the touch screen. No one seems to be able to be able to find out what the correct lead is. So if anyone knows the lead I need that would be a great help.
If not I'm in the middle of converting an audio lead and got it print much there other than when the parrot is up and running the screen just fades and you can't use it. Could do with a wiring diagram for the car stereo if anyone has them as I can then finish this conversion loom off.
Or if anyone has any other info from fitting a parrot to there car please help :)
I've had the same problems finding the right one for my satnav GS430. I think due to the fact the drivers door speaker is controlled from the boot where the satnav unit is located (for routing the voice commands to the door speaker).
I'm planning to ditch the satnav and put my double din head unit in instead. So I'll make my own cables like I did for my previous GS300's.
