Check Vsc
Dexy
Hi all, not having much luck on the IS front following the HG failure on the diesel just purchased the petrol , but on start up only I'm getting the red triangle and check VSC, the garage I've bought off think it could be a voltage fault as Battery reading 12.2 and 10.1 under load ? It isn't on whilst driving just when I depress clutch pedal to start, anyone heard of this? Feeling a bit disheartened although they have said they will sort it, any help appreciated.
Hi, oops forgot to update that ! Yes the Battery was kaput and once finally tracked down the oddball size Battery and replaced it, the warning light disappeared, should've realised because the dashboard lights seemed dim and I never twigged on. The guy I bought the car off paid for the Battery as good will. Loving the car it's costing me less in fuel than my BMW did too which is a bonus 😊
