Is250 Seat Motor (?) Noise
The power driver's seat on my '56 plate IS250 is making quite a loud noise when its moving backwards and forwards! I've done a search and came up with TSB No NV001-06, which points to the 'seat track locating pins' being at fault. Before I start dismantling stuff, I noticed that the noise is exactly the same as when the passenger seat is moved....but a thousand or so times louder!.....has anyone had the same noise and found its simply something needing lubing?
Yours hopefully!
Pete
