Is250 Headlight Polishing
My 07 IS250 headlights are gone a yellow dull colour so want to wet sand and polish them.Been reading up on it and see that there a protective coating on them.
Anyone have any problems wet sanding and polishing these or is it ok to do?
Apparently there is a coating on them, but if they are bad it is better to lose the coating. It just means they won't stay clear for as long as they did coming out of the factory so you may have to repeat the process every couple of years.
I don't agree that it's primarily the sun which yellows plastic headlamp lenses - not over 9-10 years anyway. It's mainly UV from headlight bulbs which don't have a UV filter (typically cheap high power ones). And I guess the yellowing is more intense on the insides, which means that to restore them properly you need to get the lenses off the light units and reseal them afterwards. Good luck with both of those.
Always use branded quality bulbs of standard correct power rating incorporating a UV filter.
Gtechniq P1 polish
Gtechniq C2v3 (UV protector)
Newspaper
microfibre cloth
15-20mins per headlight
There was no yellowing inside these lenses at all. In fact the only reason they were off the housings is because I was modifying the headlights.
(and just FYI - toothpaste did not remove that, and the UV damage was not on the inside. It's simply about using the correct tools, in this case products, for the job)
Couldn't tell you, as they were only done a couple months ago. Don't look any different yet though. Bearing in mind they have probably never been polished in over 10 years, they shouldn't change very quickly. It's advised to top up the UV protectant every 8-12 months.
I didnt get a chance to go at these yet as i fitted and sprayed the boot spoiler today and didnt want go near the car with polish till i had this done.I'll be detailing the car next week and will do the head lights at the same time and see how i get on.
Finally got around to doing these this week and delighted with how they came out.Started with 1500 and then finished with 2000 waterpaper.Polished back up by machine and came up like new and no sign that i cut the uv coating.If i had started with 800 or 1000 i probably would went true it but as with all polishing start off with light products and see how ya get on.
Including masking and polishing whole job was less than 20 mins.Pity rest the car wasn't as fast,spent 12 hours machine polishing the body work :)
Finally got around to pics.Taken with a camera phone and dont show up nothing like how yellow and worn they looked.They really were very faded and yellow on the top half.They look as new now.
Before
After
Before
After
Drivers side done,passengers side untouched.
