Handbrake Rear Internals
snaps
I have had an issues of my rear off-side brake overheating and after having two stuck calipers on the front earlier this year i just assumed it was the rears sticking but when i removed the caliper the disc was still sticking so i removed it and a bent tangled mess of metal and dust fell out.
I seem to have made sense of all the parts and have found new kit from GSF that seems to cover everything but one part has me stumped as i cant find it on the diagram, any one have any ideas (its the one at the very bottom that has been bent in two)?
Hi snaps,
It's part of the backing plate and it should be shaped like a top hat and spot welded on.
I expect the backing plate has started to rust through from the back and the spot welds have come away. This happened to my car about 18 months ago. I started getting scraping noises when driving, when I removed the discs everything fell out!
I can't remember it's purpose exactly but I think it is there to guide the handbrake cable/mechanism into the correct position for the shoes. I do remember trying to work out a way of repairing this but I gave up. I just cleaned everything up and put it together without.
I haven't had any problems yet and I've gone through at least one MOT although both my rear calipers are knackered so I'm about to have a more detailed look in the next few weeks when I replace them.
Hope this helps
