Coolant Change Is220D
ewan's dad
Just quck request for help, I have been doing oil and filter changes for the next few years and have also been cleaning out the EGR every 20k miles to prevent the reoccurring Check VSC problem. Thinking about other things that need to be changed is the Coolant.
So, understand how it needs to be done, checked an online resource and it says that I need to use the drain c0ck on the bottom right of the radiator (fine) and also a drain c0ck on the engine block (rumoured to be just below the coolant reservoir).
The engine drain c0ck appears to be a in a very award place, not helped by the fact that I don't actually know what it looks like, can someone help me?
To help you help me... I have found a number pictures of engines removed. Please could you play a game of find the c0ck and point it out to me?
Any help is much appreciated.
I will happily upload a how-2 guide if successful!
post-31962-0-56839800-1445526182_thumb.j
post-31962-0-90969000-1445526189_thumb.j
post-31962-0-57661500-1445526199_thumb.j
post-31962-0-13550300-1445526210_thumb.j
post-31962-0-34360400-1445526219_thumb.j
post-31962-0-42309500-1445526229_thumb.j
post-31962-0-66597400-1445526243_thumb.j
