Ls430 Air Con Pies
pheobe
Sorry to bring up an old topic but due to corroded pipes I am going to get the rear air pipes welded up but after reading old topics am not sure if they should be welded up as two seperate pipes or made into a loop, I cannot find a schematic in my manual and talking to other owners there is an arguement that they should be looped to allow coolant to circulate. Can anybody confirm the correct way to isolate the rear air con
Many thanks in advance Eric
An expert opinion will be along shortly but in the meantime I am fairly confident the two pipes do not need to be joined i.e. looped.
From the diagram I have seen the front and rear AC each have their own pair of pipes so they are not in series but in parallel.
From the US ClubLexus site either crimp each pipe for a cheap and nasty fix or fit proper stop ends near the T fittings to allow possible reinstatement in the future.
My advice comes solely from reading web sites because I will probably be going this route and not from expert knowledge.
  • 1 year later...
  • 6 months later...
Definitely do NOT connect the two pipes to make a loop under the front passenger seat- my local mechanic did this with my blessing and nearly messed the whole system up - they operate under different pressures.
The only thing I would say is to get them capped off professionally - I have a few goes with custom compression joints and failed miserably.
Front AC more than good enough for the car. It required a new condenser (circa £220 Lexus supply only) and was all done by an AC specialist near Benfleet in Essex, so too far for you unfortunately, but I can dig out their name if you are interested..
