Lambda Sensor
lexus22
Hi guys, engine warning light came on the other day but then went out. Local garage plugged in tester which showed "Lambda Sensor". Has anyone changed this before and is there only one? Where abouts is it located on a is300?
The one before the cat makes sense as it detects air/fuel mixture coming out of the engine, but whats the point of the one after the cat? I can only assume that it monitors the cat itself...
