Fuses For An Is200 Sport
I have lost the ability to open the passenger window, as well as the 2 rear windows on my is200.
The driver's window is OK.
So it looks like I have a fuse problem - does anyone know if I'm correct & if so, can anyone direct me to the correct fuse in the fuse block?
I don't have a Haynes type manual, only a user manual, & it only directs me to the fuse block, doesn't tell me what the the fuses do.
Are you sure they aren't just disabled with the button on the drivers control panel? Or that button is faulty, or the wiring to it has become disconnected. I believe the doors all have their own fuses so I wouldn't expect three to have a problem all at the same time unless the control unit has a problem, in which case the drivers window would also have a problem.
The fuse covers have the names for the fuses. The door fuses are on the footwell kick panels inside the vehicle.
Thanks for that & yes, you are correct.
Didn't know there was a button in the driver's door which locked the windows.
Pressed that & hey presto, everything works again.
