IS300h. Bug in Navigation Software. Solution.
This morning I had to go somewhere, a warehouse, which was not on my satnav. When I was there I marked the spot on the software. I then tried to name it and the software would not allow me go from the naming field to the OK at the bottom, so I lost my change. I repeatedly tried. No dice. Then, by accident I navigated to the field at the right where you can change the input type and when I pressed the downarrow, choices appeared. I just chose querty which was illuminated, the OK was illuminated, pressed it twice and bingo. Problem solved. I repeated it and it works. This MAY only pertain to the Irish version, though I doubt it.
