3Seen various techniques on YouTube for clearing misted headlights using normal household stuff so I thought I'd have a go just to see if there's any truth in what they say. A popular choice is the toothpaste method so I thought I'd give that a go. Smeared it all over the glass and used a mouse sander with a microfiber mitten over it instead of using elbow grease. Between passes over the glass I sprayed water over the glass as well. Wiping clean a couple of times and reapplying windolene cream and repeating. The result was pretty impressive as the pictures should show. I just need to pick up some car wax and give them a buff to help seal them. OK,  it might not last forever but it didn't take long and I didn't have to go and buy anything, so the total cost was £0.
42 minutes ago, lex - eleven said:
adventure before dementia
I`d have used Sterodent !!! (You`ll wonder where the yellow went...............)
Looks good Mark.
Lots of advice on Mercedes Forums and Youtube of course.
Regards
John
Looks good Mark.
Regards
John
Not wanting to show my age but it was Pepsodent that enabled you to wonder where the yellow went!  I used mettalic paint T-cut on mine, worked well although they weren't too bad anyway.  Better results than the kit that I wasted £25 on last year.  I think when they've been polished it is necessary to do them again from time to time as it removes the original coating.
But you are showing your age Phil.....and you are correct,it was indeed Pepsodent.
I`m drinking too much Rioja here in sunny Spain!!
Regards
John
Regards
John
Just rub it in why don't you, Rioja being my favourite wine!  Anyway, I'm sitting here in sunny Sussex with a bottle of Prosecco and a bar of chocolate after our takeaway curry.  Not as good, but not too bad. Hope you're having a fab time.
Cost £0? Ah, I see....the fact that your WIFE does the shopping means toothpaste and Windolene somehow are 'free'!
As is the slap around the head when she looks and there's no toothpaste  for her to use?
.......  ask your local bodyshop repair guys, there's a product they professionally use that's about £22 that does both headlamp settings and more or less lasts forever ( they say ).
The repair shop might charge you £80 to do the job using this product !
But I don't know it's name
I've done a headlight clean on my BMW 530d a few months ago and went the labour intensive way.
Started with 400 wet n dry and working my way up to 2500. Then machine polish with a light compound, then hyper polish and finished off with Autoglym Super Resin Polish as this has a UV block. Only cost me electricity as had everything in 'stock' :)
Results were pretty awesome really (forgot to take a 'pre' picture of driver's side headlight, but it was slightly worse than the passenger side shown)
18 minutes ago, lex - eleven said:
£80....I think I'll stick to the Colgate!
Or maybe just buy the kit !
