Door Card Light Issue
Hi Folks,
I have a small issue in that the passengers door card light is dimly lit, whereas the drivers door card light is brightly lit.
I probed the back of the connectors with the lights disconnected and both show a healthy 12-13v reading, when i connect the light up and probe the back of the connectors the passengers side drops to 5-6v and the light is very dim, where as the drivers side stays about the same voltage and the light is bright.
Does this sound like a ground issue with the passengers side light?
any help would be much appreciated.
thanks
John
I'd be inclined to say poor ground somewhere in the circuit.
Might be best getting a local auto sparky to look at it. Sounds like you've done all you can, unless you feel confident removing the door card?
Hope you get it sorted. :thumbs_up:
Hi. Had the same problem on my is200 - but with the drivers door light. When I tested it was showing 8 volts. I sorted mine by cleaning the internal light door switch. Hope that helps.
