OBD Results
JDMtom
Hey All,
I haave been having some running issues on my is200,
OBD scan gives me the following codes :
P0110
P0135
P1300
P1305
P1310
I know there is a list on the forum somewhere of error codes but cant seem to find it.
What do the above mean and whats the fix for them ?
Thanks,
Tom
Ok bit of an update,
I was changing my plugs the other day as I had developed a misfire, Before I swapped the plugs out I decided to disconnect a few Coil Packs ( 1 at a time ) to see if it changed the  running of the engine.
Only remembered this today, so cleared the codes before going on lunch then returned to work and checked codes again. Only P0110 remained.
Would this error cause misfire/gutless revs?
OK so had a look into the air intake temp sensor - I dont actually have one :D - so i guess i better find one.
checked codes after the 30 mile trip home and i have P0135 as well now :/
