Rear Under Run for Lexus RX450h
Hi All
I have just noticed that the rear under run for my RX450h has started to come loose from the chassis near the boot. I can see that there is some kind of adhesive exposed.
Before I address this can anyone let me know the best way to fix it.
Tom
3 hours ago, Haken8 said:
Hi All
Tom
If its just adhesive holding it up you just want some adhesive but make sure it's waterproof
Hi Rayaans
I decided to ring Lexus Milton Keynes and they said to bring it in but would have to leave it overnight for bond adhesive to harden. They are even giving me a loan car. Great service from Lexus
Tom
Stixall is very good general purpose adhesive. Water resistant, sets in wet and joint is slightly flexible. I have used it to patch holes in a zinc roof. After couple of years I had to replace it as not UV resistant. It doesn't work on soles for shoes but it does for everything else I have tried. Tool station sell it for £4.82. If you don't have Toolsation try builders merchants. It is an Ever Build product. No connection except as user.
