Is220d delayed turbo response
peachy
I've had my is220d 08 reg jus over a year now and all has been good up until last week.
The turbo used to kick in at just under 2000 rpm and off she went.
However  since last week I have had no turbo response what so ever  until I reach 3500 rpm.
The car is as dead as a dodo now until it reaches 3500 rpm and then it goes like a rocket.
No warning lights on the dash and everything else seems fine.
Any ideas before I give lexus a bell?
3500?!?!  I am amazed it is even driveable!
I was once told that if the turbo boosting is delayed, then the EGR valve needs looking at.  Although that was for a slight delay.
Perhaps the wastegate on the turbo is stuck partially open?
Any other symptoms?  Rough running?  Smoke out the back?
Don't think so.  Shame really since it could have helped with the lag problem.
One sure way of knowing if there is a problem with the turbo is plumbing in a boost gauge.  The manual suggests testing peak boost, but I don't see why you couldn't drive around with a passenger reading the gauge to see when and how much the turbo is spooling.  Max pressure should be between 6.9 to 7.7 psi.
