R19 Michelin Crossclimate tyres
Hi when checking what the tyre pressures are for my new Michelin Cross climate tyres 235/55/R19s, it seems that there are different answers. On the Michelin website it states use only those pressures on the door pillars recommended by the vehicle manufactures not on the tyre side wall.
So here are the ratings
Lexus tyre pressures
So looking at the ECO setting 36psi seems correct?
2ddesign
Surely the pressures on the tyre sidewall are the maximum inflation pressure the tyre can withstand, normally during mounting on the rim, certainly not driving pressures.
Yes, looking at that image the correct ECO driving pressure would 36psi
Tyre pressures rarely change with tyre make. Pressure is determined by axle weight. It might be prudent to use the higher pressures in the recommended range with very low profile tyres, to stave off snake bite punctures.
