Is220d non start
B5rs4
Hi, I'm new to the site and wondered if anyone can help or had a similar issue??
have replaced head gasket and 2 injectors, now the car does not start! I have no power at low pressure fuel pump/injectors, basically the whole injection loom. Fuel pump relay is not switching either. Have coded the injectors, check all fuses, earth cables etc, anyone have any ideas??
Yes it has been primed, I have fuel coming out the supply line when I use the prime switch in the car, but no power at low pressure pump/injectors/fuel pump relay. Could it be a fault with the infection driver (ecu)?
