P1651 - Valve replacement
c33
Hi folks, getting round to sorting the P1651 fault on my '02 LS430, do i need any parts and gaskets other than the throttle body gasket and main inlet manifold gaskets - and obviously the valve 25860-50100? Does the upper section of the plenum need removing to remover the lower section or can I pull the whole lot off in one go?
Regards
Iain
