LS430 Coolant temperature sender location
cakehead93
Hi everyone, if one of you could point out the location of the coolant temperature sender which sends the signal to the temp gauge next to the speedo as it says the car isn't up to temperature after a even a motorway run, its also not allowing the car to change up to 6th gear as again the car thinks its not up to temperature. id be very appreciated if one of you could help me as google wont help me and  is constantly showing me results of the LS400.
Cheers,
Rob
There is always the chance that it is not the sender but the car is getting over cooled, sounds like you need some diagnostics to confirm the issue...
The sensor is located here...
350430d1419717232-replacing-the-engine-t
