Headlights and light wash not working
IKHbike
Replaced left hand number plate bulb and for 30 sec brake light on dash off and everything working then headlights go off,headlight wash not working either .There is a separate ecu for both R and L H'light and one to wash motor behind f'bumper.Headlight fusses good but main relay in under bonnet fuse box not appearing to click(When lights switched on power to two of four pins in fuse box) I might add that both front f'fog lamps are disconnected and wires cut,both rear fog lamps are fine(but not operative) I have no idea how long bulb to number plate blown as have been tracing a TRC  and brake light issue(TRC working) ,why would the bulb being replaced affect the relay if that is it.Thanks for any ideas
Seems if we pull stork back to flash head light it works,also when relay removed last night the day day driving lights came on but not headlight. opened the headlight relay and its fine.So power to lights and bulbs work and relay intact,and before number plate bulb replaced all fine.Not sure where electrical issue part of forum is so sorry if in wrong section.
