AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Drove to Luton Airport this morning. All fine.
3 hours later to go home, car unlocked, then dead. No lights, no ignition, nothing ...
Called Lexus Assist ( AA).
30 minutes later, they arrived and the car has started.
The problem?
The connection to my battery had come loose(!), so it was effectively disconnected for maybe 3 hours.
It took about a minute to be fixed.
It's never let me down before, so I WAS surprised!
I guess the car has to re-learn stuff now. Certainly some of memory settings have gone... But a happy ending.
Top Tip: Keep a coat in your car. I had one ( a high viz ) and was I grateful!
:xmas:
... and check your battery connections!
Never thought it would come loose, but it did.
Maybe it's all these potholes we have to drive over...!
I bet you were relieved to find it was nothing major!
Do you know if that was the original battery Piers? Mine is the original, and will be 12 years old on March 1st. Is it common for a car battery to last that long? or maybe I've just been lucky. Anyway glad you got it all sorted.
On the subject of batteries I have a Motorhome with a 3 litre diesel engine that has not liked the recent cold weather. It was really flat so i thought I'd try a Jump start pack from CostCo ( PSX3). I was amazed to see the van leap into life and the unit now has a permanent home behind my seat in the RX for emergency use. It has an emergency light, a 12 volt DC out as well as a 5 volt USB out and a tyre inflator  that pumps up to 150psi . So it won't be going back to CostCo !
12 years!
No, mine was changed last year.
Ironically, I suspect when the new battery was fitted - by a good independent - it wasn't quite tight enough? maybe?
And the CostCo device sounds great!
Happy days.
Piers.
Piers, Thank you so much for your post, re, all electrics cutting out. The same happened to me a few days ago, & again this morning. Thinking it was a faulty relay, I was dreading the bill for finding the fault, on my RX300. Then I remembered your post, & tried it. Blow me down the connector moved when I grabbed hold of it. I couldn't believe it, as I only had the battery off 2 weeks ago, & has cured fault. Thank you again, & it shows how vulnerable the average person could be, with an unscrupulous mechanic.
Ian Verdon.
Ian Verdon.
Sometimes the best solutions are the simple ones!
:whistling:
  • Similar Content
    • By Arqum
      Hello peeps. So my replacement battery i had was a Toyota Optifit which tbh im not happy with. Been 18months and its struggling as the days get colder. I bought a Ctek charger which charged it and it was ok for a day and then when i measured it across the terminals i was only getting 11.8v
      Can someone who has the original factory fitted battery take a pic for me and if they can find out the spec and part number from the battery please?
      Cheers
    • By WilliamH
      Had to get a replacement battery in a hurry today for my 2003 IS 300 Sportcross, so went on-line.
      Eurocarparts website was easy to use and had a tasty discount offer. They had a choice of 2 so I selected the more expensive one with 70Ah, CCA 540A, rating and ordered it 'click and collect'. £67.40 inc vat and 3 year g'tee which I didn't think was bad.
      Now I've got it home I can see it doesn't fit the battery tray properly. The base area is too big to fit deep in the tray so it sits quite high. Also, the new battery is 10mm taller than my knackered battery. As a result, the standard battery clamp won't fit (the rods aren't long enough) and the terminals are worryingly close to the closed bonnet.
      Is this a common issue?
      Is there a work around or will I have to return it to eurocarparts?
      Is there a generally recommended/ easily available battery that fits?
      Thanks in advance for your replies!
    • By PCM
      that... the SatNav on my RX has a compass.
      Yes, I know it sounds obvious, but I just never realised it before!
    • By Nickyt211
      Hello this is just a question out of curiosity, I've cleaned and polished my new rx300 2004 plate I've had it 2 weeks now and I believe it's running on it's original battery it looks a bit old tbf, it's a Panasonic battery and it says distributed by Toyota on it. It can't surely have lasted this long can it? Lol
      My question is which battery do you guys think would be up to the job, which brand do you recommend. Just interested in makes and models etc. Thanks
    • By Zlightbulb80
      Having a nightmare.
      Lexus IS 220d SE-I
      1) Battery died
      2) Replaced for new. COCKED UP, got the polarity wrong and fried the electrics.
      3) Checked all fuses, replaced several micro fuses and the entire fusible link. CAR 90% works, fully drivable etc however,
      PROBLEM
      Windows - The on side (passenger) front and rear windows do not work from the doors themselves or the driver's master switch, completely dead. Also the red light at the bottom of the passenger front door isn't illuminated suggesting it might not be just the windows? The wing mirrors do work however (illuminate and fold in, separate circuit??).
      Climate Controls - A separate point, the climate controls are dead, the stereo is operable from the steering wheel and the clock displays, but the main unit above with heating, air con and stereo adjustment is dead. Any ideas?
