Good afternoon Lexus Owners,
I am facing problems with my Lexus IS250 (2006MY) and I was wandering if any of you will be able to help me. Since nobody so far was able to give me a guide.
The problem is that when I am trying to unlock my car (by using the fob or the key less entry feature) only the driver door is unlocking.
I am aware of the feature were it can be set up in a certain way but I have done it and re-done it without any success, hence I do believe it is a system fault or something like that.
Also the car Battery and the fobs batteries have been changed wishing for a success.
Thank you in advance.
Have a nice day.
2 minutes ago, NemesisUK said:
Do you have a spare fob you can try?
How are you setting the preference for remote opening?
Yes, I do have a spare fob and I face the same problem.
The problem is present when I try to unlock it from the inside door buttons as well.
When it comes to the preference do you refer to - keeping the lock and unlock buttons pressed together of from the MINI VCI diagnostic tool (because I have used both)
Cheers.
Maybe the lock/unlock button combo is different for your model?
I reckon I saw somewhere (US manual?!) that the reset procedure for my GS is press/hold unlock/boot release.
I've not double checked the hard copy of my manual yet.
Is your ignition off whilst performing the reset?
