We have a new (Dec 2016) GS450H - very pleased with it but some of the plentiful features seem a bit 'half-baked'. We had a top spec 2012 Volvo S80 before, this had most (but not all) the GS450 features and they all worked well e.g. the road sign recognition system worked 100% whereas the Lexus equivalent misreads abut 40% of speed signs (Lexus admit that here may be n issue with this). The radar/detection system for the adaptive cruise control doesn't seem to 'scan' as well as  the Volvo system and misreads traffic a little resulting in occasional un-needed heavy braking etc. As I was driving last week, I thought I'd try the voice command system by saying 'Go Home' - I was quite impressed when the satnav seemed to respond correctly but I couldn't understand why guidance hadn't started - a brief glance at the screen showed that I needed to select which route to take (avoid motorways, tolls etc.) - I wasn't in  position to start messing around with the 'mouse' device to select the on-screen options thus the whole exercise was a waste of time - is there a 'work-around' for this?
I have a 2008, so not as modern as yours. I can turn the heater up and down and turn audio on or off but I've pretty much given up on the rest. :)
That nice lady doesn't understand me and when she does, she say the command is not available in this screen.
In the setup menu for the Nav system one can turn off route selection, or set a default.
If you don't have a manual for the Nav system you can download a PDF version from the Lexus customer portal
Coming from a Prius Tspirit to the Lexus GS I found the voice control system to be identical so I was ready for it's foibles.
The system is not as intuitive as it should be, but once you have all the settings to your requirements it does work well. I agree sometimes the message "this command is not available in this screen to be a useless piece of information. Why could the voice not say change to the required screen "naming the screen" or even better change to the correct screen.
I regularly use the command "home", and the navigation has never failed to respond correctly.
John
