Thanks Peter/Mark
The auto GMT/BST was off, wouldn't you think the handbook would mention there was clock adjustments in the general setting.
Thanks again.
D
Kind of linked, but does anyone's clock (older model) have some random time when first get into it morning, and takes a moment of two to correct itself?
I leave circa half 7 in morning, and several times I've notice it be circa 1 and some minutes out, I.e. 6.11 random times. Few mins later its on the correct time.... made me think I'd left early more than once!
Could get it if an hour out etc, but the random minutes are puzzling as aren't just a couple.
Setting is on auto and I've rolled on the hour via summer time, but did same thing on winter time to (St off).
I get the same if I set the set the clock to auto time set. If I leave that function turned off it behaves correctly.
John
Seemed to work, how random lol. Wonder what clock setting it's defaulting to when no signal to actually set it..... and perhaps adjusting that one can then mean both work ok?
There has to be some Japanese logic working, but do not ask me what that logic is. The same logic that gave the Prius in Florida heated mirrors while they were not available in the UK even as an extra.
John.
