Mailo87
petrol leakage engine
Hello folks.
I just made my 6 month visual check of my timing belt, and it looks very good. But I noticed some petrol leakage..
Looks like perhaps the washer on that big petrol hose needs replacing? what do you guys think? :)
Best regards
Robin Abrahamson
I'm pretty new to the 1G-FE but I don't think that's a petrol hose lol. I think it's an oil feed line for the cam gears maybe?
Hmm, im nut 100% certain myself but the nut/hose setup looks identical to other petrol mountings I have seen on other cars.
Anyone know for sure what this pipe is? :whistling:
Updated my comment, I think its an oil feed for the cam gears.
sounds logical based on its location. I will bring a photo to my dealer tomorrow and ask them to find out. Ill update with the answer.
Thanks so far ax53!
no problem. Upon further investigation i think it feeds the oil for the VVTi system. So in that case it doesn't serve a lubrication purpose which is a good thing. Also the fitting type is called a "banjo fitting". Good luck
