mep
220d SE dash looks like a xmas tree
Hi everyone. It's not Xmas but might as well be.
I had a problem with a worn rear wheel bearing. The car had been used to tow around an exhibition trailer in its early life and at 175,000 miles started to complain. I'm not complaining as 175K miles is still good value. To look at car is immaculate inside and out. Still gives 40MPG and I am still in love with car after 7 years of ownership.
Changing the bearing I managed to damage the ABS sensor: and when trying to remove the broken sensor, I damaged the sensor ring. To make matters worse, thinking I could repair the ring, I removed the sensor ring.
Duh! What was I thinking.
The friend, whose garage I was using to do the work, suddenly needed his garage and so I had to move. I drove the car home and parked up.  On the way home. No Speedo. P/S Red light on even though power steering feels okay.  ABS light on. Engine light on. VSC complaining.
So now I have a replacement hub, with ring, new ABS sensor fitted and all on the car.
But all the lights still on.    I have tried removing the Battery over night.  All lights still on except Engine light.
Any one with any thoughts before I troll off to my Lexus dealer who will want more money than they value the car at to plug in their OBD reader.
Hi Martin,
Good to hear of a 220d owner who loves his car.  175k is quite a bit of usage, so it nice to hear that the car is still going well.  Towing a trailer also sounds like it has worked hard.
Sorry to hear about your troubles, it does sound like a pain.
The only thing I can suggest is getting your own OBD2 reader to find and clear any faults.
Something like this should do the trick:
http://www.ebay.co.uk/itm/U581-Car-Engine-Fault-Diagnostic-Scanner-CAN-OBD2-EOBD-Code-Reader-Scan-Tool-UK-/231514532804?_trksid=p2349526.m2548.l4275
Alternatively, with an app on your phone, you could use something like this:
http://www.ebay.co.uk/itm/NEW-Mini-OBD2-ELM327-V2-1-Bluetooth-Car-Scanner-Android-Torque-Auto-Scan-Tool-/162312931706?hash=item25ca9ac97a:g:BmoAAOSw2gxYpXEH
Hopefully it was just complaining about the lack of ABS, so once you clear the code, everything should be back to normal.
I have already tried a OBD reader made by AEG but consistently get "error scanning".
Well, that is strange.
I have the ELM327 Bluetooth scanner and it works fine in my car.  The other one I linked was recommended from someone on here, so it should also work.
Just to compound the problems, When holding down the unlock button on the remote to open ALL windows, now the drivers window refuses to open even though all others do.
Assuming that the window works properly otherwise, that is another unusual problem you have experienced.  If you open it manually, do they all close when you hold the lock button?
Well. Out of the blue the window has started to work. Don't know how or why but thanks for responding.
Hi everyone. I bought the the exact same OBD scanner as recommended above. Connected to car, turned on the ignition, exactly as there manual states: and the readers states NO CODES found.
Anyone with any ideas?
Car reports.  ABS fault. P/S Power steering, Brake Warning, VSC with red warning triangle and the OBD Reader reports: 'There is no codes in the vehicle'.
So the engine management lights are on and it says 'Check VSC', but the car still has no fault codes?
I didn't think that was possible?
Off to the local Lexus dealer Monday. See what they make of it.  Everyone else seems baffled.
It is rather baffling.
I am curious to know what they say, so please keep up updated.
After a lot of elfin about........  Remember this all started after having 2 new rear ABS sensors and both rear hub bearings replaced, Lexus Toulouse decided to change one of the new hubs for another new hub and replace one of the new ABS sensor with another new sensor.  Problem did not go away! They then wanted to do the same the other side and i refused.  So they then came up with a scheme to take the magnetic part of the hub from the one they swapped and fit another new sensor.
€1463 later I set off home and half way home the VSC light kit up again and so has the ABS.
At least the speedo, the cruise control and odometer works as is the fuel gauge that is now stable.  As for the OBD reader I purchased... WASTE OF MONEY!!!
DO NOT WASTE YOUR MONEY ON THE OBD READER TALKED OF ABOVE.
Thankfully having spent €1463        I have somewhere to go back to.
But keep in mind that this is a 10 year old car with 190,000 miles on the clock.  Right now other than this problem the car runs absolutely fine and still looks good for its age. I cannot afford to change the car so I am having to bite the bullet and keep on paying.  But!!!  If the dealer had their way, they would rebuild the mechanics out of new spare parts till it was like new.
Comments like, "it feels sloppy and loose, not like a new one" sits in the memory.  i do wonder what these people expect?
  • Similar Content
    • By Ibbo
      I require a replacement ABS Brake Booster Module for my 1998 GS300.
      the original part number for the module was 47210-30160 but this was superseded by 47050-30160
      Can anyone recommend where I can purchase a refurbished module?
      Many Thanks
    • By Ibbo
      Many Thanks
    • By Stephenlexusis220d
      Hi, I do not really have any idea about cars at all, upon starting my car this evening (lexus is220d ) 2007 I got the vsc error and turned on the engine and Tc lights. Would this be from a filter problem, I have had no problems before. It is due for a service in 2k (currently 80k)
      would you recommend to call the road side assistance and ask them to define the fault or to take it to a garage or a dealership and ask them to asses
      any help is much appreciated
    • By Nigel_S
      I wonder if anyone can shed any light on an issue I am having with my 2005 RX300... please?
      I noticed a little while ago that, occasionally, under normal (not harsh) braking at low speed, or under normal (not harsh) acceleration from standstill, either the ABS or Traction Control would kick in.
      The ABS "effect" seemed to be coming from the off-side front and so at a recent service I asked the garage to check the ABS rings and examine whatever they could get into, on all four corners. This they did and reported that everything appeared as it should be.
      More recently, I was advised that the issue could be a dirty ABS/Speed Sensor (maybe a small piece of road dirt or debris had become lodged etc...) and that if it could be removed it might be cleaned, however, they also had a tendancy to break if not having been removed before and so the best course of action would be to buy a new one and change it completely. This I did and the work was completed just a couple of hours ago ...and I can report that it most definitely appears that the offside front was the culprit because now, pretty much every time I pull away, the Traction Control kicks in!
      The only thing that has been changed was the sensor (Part Number checked before purchase and fitment), so I can only assume with a new sensor in place the issue has become more apparent.
      So, can anyone offer me any advice as to what to do next?
      Is it worth going ahead and changing the sensor ring, just in case, or has anyone else experienced this and has a "fix" that works?
      Any help/advice/assitance would be greatly appreciated.
      Many thanks.
      Nige.
    • By Yobosoku
      Hi, new to forum, there may be an already existing thread but I cannot find anything......ANYWHERE! I need an ecu pinout for a 2001 is200 using a 1gfe with an ecu number 89661-53200. I need this pinout diagram and expertese to fit a bee*r limiter basically because I want one and I like being a loon in my car. There are people who hate/disagree with them, however I would like one in my car and I would appreciate help fitting it.
      any help appreciated.
