fuel filler cap cover
Hi All
Has anyone had an issue with their cover plate for the filler cap coming loose? Believe someone has tried to pull it open and i noticed when i was washing the car yesterday that the plate was sticking out slightly and a bit wobbly.when i slide it off found that one of the little molded tabs was broken at the hinged end on the plastic flap.Refitted it as i needed to get to work so had to leave it until this afternoon. I took it off again and bent the small cutouts on the plate that slide onto the plastic tabs, put a bit of plastic glue in the area where the broken tab is and it seems ok. Will have to trial it for a while but does it warrant a visit to Lexus at some point as my car is still under warranty until November? should i chance my arm to see if they would  replace it as faulty?
with there being plastic glue on there i am sure lexus will say no
as its had a non approved repair already
http://www.car-transplants.co.uk/used-parts-breaking-vehicles/#vpt
they have some 300h in stock for breaking
they also have a tesla for breaking if ganzoom is looking in not sure if its his model though
