Tow bar live feed question
J  m
Not having an IS220D I cannot say for certain, but I assume the 12 volt Battery is under the bonnet. If it is it is most unlikely there is a suitable feed in the boot. Again I assume your going to tow a caravan with a fridge. This will require a minimum of a fused 10amp supply, and more ideally 15 amps.
Running a wire through the car fused from the Battery, and switched with a relay from an ignition feed is the only solution. This is so the car Battery does not get discharged when the engine is not running.
John.
