Just to quick queries long-term owners may be able to answer.
1. When I set a destination on the satnav, on both my previous IS and my wife's CT, it was not necessary to click "Start" - after a short delay to allow you to add further destinations to the route, the navigation started anyway. However, it appears the NX requires this (and it cannot be done by voice control).
Is this correct? Or is there a setting which allows this to be changed?
2. The boot is automatic (so far so good), but it has to close all the way before you can lock the car. As it takes a while, I can see this getting slightly irritating.
Can this be set so the car is locked in advance of the boot closing?
I believe the answer is no to both
Item 2 irritates me a little on mine I must admit. I've just got used to the first item. Would like a Home shortcut mind!
It seems to be a UK thing. US gets the button where you can press it twice and it'll lock upon closing.
Same with the RX.
I've actually hit upon partial solutions in each case.
1. If you navigate away from the navigation screen by doing anything at all, the route starts. Since I generally only use it in half screen anyway, this means I can simply set home and I'm good. (There is a home shortcut - I think Paul maybe means there is no "back" shortcut? Even the CT has that, so I do miss it a little.)
2. I hadn't realised that the boot closing or opening can be stopped from the key. That means, for example, it I just want to grab a briefcase from the boot I can stop the opening with the key quite soon after it starts, and when I press the key again it takes no time to close from where it is.
Which makes me want to try that double press thing now...
The newer IS models have a Home shortcut from the main nav screen which I quite liked. In an NX you have to go through a number of clicks from the nav screen to select home as destination. Given that almost 50% of the journeys I do when I need the satnav on are me going home, a shortcut straight from the main nav screen would be useful. I only have the basic nav though so maybe the advanced setup has this?
Interesting what you say about the route starting automatically Ian. I was wondering why mine occasionally started automatically.
Be wary of stopping the boot opening all the way with the key or button on the lid. I almost always end up smacking my head on the way down or usually on the way back up. I've just got used to waiting for it now. You can change the height to which it opens though within the settings menu. Being short of stature, I have mine set to not open all the way which makes it a bit quicker.
Same with the RX.
Wonder why? You'd think something like this would be the same on both sides of the pond.
Re the boot, yes, I had to leave the setting at 5 for that reason (and I'm below average height).
I see what you mean re the home shortcut now. I am not sure which Nav you have; on mine there are six destination presets at the bottom of the destination screen, one of which is "Home" (so you are actually only two clicks away - "Destination" > "Home"); or I can use voice control simply to say "Go Home". I don't know if this applies across the range.
Blimey. You've got me thinking I might be missing something. I'll check next time I go out. Cheers!
It's definitely on all models with premium nav fitted. My 3RX had this and so does wife's IS and new RX. I can't remember whether it was on the standard nav system though
The other thing is that merely pressing the voice control gives you the option simply to click "Go Home".
I have standard nav so no Home shortcut. No voice control either. I'll just have to stick with the lots of clicks and twists
  • Similar Content
    • By joelfigueira
      Hi all,
      Has anyone bought a SAT NAV update from this place? Seems to get good reviews etc and loads cheaper than getting it form ebay. Also like some other copies you dont need to disconnect the battery as part of install.
      https://satnavstore.com/
    • By ds001
      Had my car a couple of months now and been generally very impressed, I don't know why these cars are not more popular, a lot of car for £5,000 !
      Anyway, the boot will not open using the button in the car or the latch on the boot itself (it will open with the key)
      I have checked the switch in the glove box and I assume the fuse is ok as the fuel filler cap still works and according to the manual it is the same fuse.
      Anyone got any ideas or come across this before?
      I did take out the Lexus warranty, would this sort of thing be covered?
      Many thanks.....
    • By Ian J. Parsley
      I thought it may be useful for all Forum members with or contemplating Premium Nav to outline my experiences with it over the past month - as I seem to have encountered most of the problems but also some of the solutions.
      Fundamentally, Premium Nav adds an Internet capacity to your satnav. This enables it to pick up traffic conditions (and offer alternative routes), note parking options in cities, allow online searches (which will provide phone numbers as well as navigations options) and send journeys from your phone/tablet/computer to your car in advance.
      (It adds a few more things too, like an advanced reverse camera and DVD player, but they're not relevant here. For the record, it also adds the capacity to save a journey to a USB and transfer this to the car that way.)
      The first thing is you need to register with MyLexus. Previously there was a Lexus Portal, but this has been replaced. However, the fact is there has been significant confusion over this.
      NOTE 1:
      Your sign-in name (an email address with MyLexus) is *not* your User ID. Your User ID by default will be the first part of your email address, but you are wise to change this as it may clash with others (or just cause confusion with past portal registrations). You change it my going to "My Details" and "Edit" and it is at the bottom.
      Once you have registered you need to register your Multimedia device. This is a 16-digit number (to be typed in without hyphens, even though they appear on the screen). I found it easier to do this online than in the car, though both are options.
      You also need to verify the vehicle. For this you need a six-figure number from your logbook (like ABC12D) - this is a chore when you lease because you need to get a scan from Lexus Financial Services or the lease company; and even more of a chore when they lose the logbook...
      NOTE 2:
      If you cannot get this number, ask your dealer for the one they use for demonstrators. That seems to work.
      Now the key is to connect to the Internet. This can be tough, at least with an iPhone.
      NOTE 3:
      You need to have tethering on on the phone (apple calls this "Personal Hotspot"; other companies use slightly different names).
      In theory you can connect for tethering via Bluetooth or WiFi.
      For some reason I cannot do the former with my NX (worked fine on my IS).
      The latter is a bizarre hit and miss and seems to require not only that the Personal Hotspot be on, but that the specific page be open. Weird.
      NOTE 4:
      This is where I get a little lost...
      Via Setup > Navigation there is a Connected Services menu which allows "Delete Username and Password" or "Change Username and Password". If you try the latter, you need your *User ID* (not the email address) and password. It may be worth keeping these short!
      You then click "Save" and that should simply save it - but if you are unlucky, it will go to connecting and a lovely error message. This means your tethering has broken down, your password is wrong, you've forgotten your User ID, MyLexus does not feel like working, or you've the wrong colour socks on today...
      If you get through this, try your luck with an Online Search on "Navigation > Destination". Here, you will go to "Connecting" but hopefully not for long. If you do, the above paragraph applies. If you don't, you're in business.
      NOTE 5:
      My success rate in currently about one in four...
      ALL TIPS WELCOME! :)
    • By Ian J. Parsley
      Lexus still has not been able to locate my logbook so I was given another number today with which to verify my vehicle.
      From the MyLexus point of view, this appears to have worked. The car is deemed verified; it says it is connected to the multimedia; and I can send journeys to the car.
      Unfortunately once I get to the car it's another matter. Any attempt by any means of typing in my Lexus ID and password is met by a could not connect message, "ID=195".
      This has come up before on these forums but I reckon I am doing everything advised. Any further thoughts?
    • By Keleko
      Evening,
      I've got a 2012 GS450h F-Sport and I have to pull the boot lid pretty hard to close it, should it have a soft close boot like my 2008 GS450h did?
