Hello
i brought my rx300 a few weeks ago now as helped by you all in my previous post. I'm now looking into the adjustable coilovers it has fitted. I'm sure that at the minute it is set too low. I'm going to be taking it to a garage this week so I wanted to ask, Does anyone know what the standard ride height should be for a 2004 rx300? So that I can tell them. The other question is is it something I could do myself or is a professional advised.
thanks guys
1 hour ago, Nickyt211 said:
Hello
thanks guys
The ground clearance for a 2nd Generation Lexus RX is exactly 7.09 inches which is 180mm
I'd be letting a professional do that unless you know how to work a jack and have axle stands so it doesn't fall on you
The suspension geometry will need checking and probably correcting once the ride height is changed.
Noted I'll get it done properly. Is that measurement from the floor or the wheel?
It's the ground clearance so will be from the floor to the lowest part of the car at any point - good mechanic will know what you mean
Rayann is correct to say 180mm but I just wanted to point out that that is the minimum clearance, so presumably it can be higher if so desired. I have no idea what the consequences of that would be, whether it would give a better or worse ride, whether it would be safer or not, I don't know - it just strikes me that as they spec it as a minimum, then there must be room for manoeuvre as it were.
Ride height is from the floor to a specific point on the suspension mounting crossmember but as Rayaans says, a knowledgeable mechanic should know.
Try and find an alignment specialist. I used Wheels in Motion might be a bit far for you but they are the gurus where suspension geometry is concerned. They set up my lowered coil-over setup on my Mercedes.
My husband has measured and at the minute it's measuring from the floor to the lowest part which is the sill. 185mm so just above minimum. On a website we found specified that from the centre of wheel hub to the highest point of the arch it should be 45cm on the front and 47cm on the back which sounds right as mine is running 2-3cm lower than that they seem all over the place
The lowest part of the vehicle includes any components which aren't supposed to touch the ground. Id check underneath the car as from memory there are components lower than the sill. I think it may be one of the pipes for the exhaust or the space saver carriage.
In my 450h the lowest part is an exhaust pipe in the mid section which is lower than the sill.
That's a very pertinent point, well observed. Yes, having had a peek under mine there are certainly items lower than the sill.
I assumed it meant the sill as surely the underbody parts wouldn't change height massively as the wheel height won't change with the suspension. I.e all the axels transmission etc.
Stub axles are the only parts that don't change height above the road. All other bits of the car are supported by the springs and they determine the ride height.
  • Similar Content
    • By Matt96
      I have owned my is250 2011 for 1 year now. Full main dealer history. 58000 miles. Main service has been done. Over the last few months when braking and steering at a low speed there are a couple of clunks that sound like they are coming from the front drivers side wheel. I look it to lexus Hatfield and under warranty they replaced the shock absorber and top mount. The car seemed to be ok for a while but not long ago the clunk noise has appeared again. It also only happens when the engine has warmed up. Some people have suggested the pads are moving but the pads and discs are reasonably new so shouldn't be moving yet. Any ideas
    • By aderz
      Hello, I'm new to this forum but have been lurking for a while :)
      I have the dreaded "OFF" light blinking at me on my 2004 RX300 so will be taking it to a local garage for the diagnostic code to see why (my scan tool doesn't find the suspension codes). Now as each part of the suspension seems to cost around one first born child and a kidney I was thinking of swapping the air suspension out for a normal strut and spring set up. Obviously I will only do this if the replacement parts needed for the fix are the struts as these seems to be the killers and they all look to be basically as bad as each other so even if I change the one that's leaking now there is nothing to say another won't fail next week.
      So my question is this, to convert from air to spring suspension, is it just a case of swapping the struts themselves and the top mounts or is there more to it than that? I know I will have to pull the fuse on the air compressor to stop the warning light blinking at me but are the suspension turrets the same physical shape on air and spring cars or are they different?Looking at other posts on the subject people who have looked at this in the past have talked about changing to a coilover setup but I can't find any in the UK.
      I was going to find a scrap yard that had a RX300 there and just take all the of the struts with springs attached as one unit, ive swapped out shocks before so it doesn't present a problem other than trying to undo 14 year old rusted on bolts in the rain......
      Thanks in advance.
    • By Amberflame
      Hi
      Hoping for some advice with an ongoing issue with my GS300 06'. My steering is very loose with pulling (mainly left). The ride is very bumpy and encountering potholes or bumps is a rollercoaster experience!. To give you some background, I took my car to Lexus dealership last October and they completed a 4 wheel alignment which solved the issues for a few weeks but now all the issues have returned with the steering feeling even looser. This is the second wheel alignment I have had done in the last 12 months both times presenting the same issues and I am at a loss as to what to do now as the garages only seem interested in performing a wheel alignment and this is clearly not the problem. Could it be the rack and pinion or the steering block? I have the tie rod ends replaced not long after getting the car so I don't think it can be that. Any advice would be appreciated.
    • By Socket786
      Hello All
      I am having problems with my existing rear suspension due to load ie two lpg tanks, petrol tank and passenger use.
      Is there anything on the market that's slightly uprated to take a heavy load.
      Awais
    • By lee2831
      Hi all, new to the forum and possibly new to Lexus, I am in the market for a used rx 300 as a second car and I have seen 2 candidates, a 2004se and a 2005se-L, they are similar money, the older s.e has about 25,000 miles less. I am really interested in the s.e-L for all of its toys, but I'm somewhat put off by the air suspension, as in its reliability worries me. The consensus points to it being fairly unreliable. So do I take a punt on the younger prettier one with air suspension, or the older but possibly more dependable s.e? Thoughts and experiences will be greatly appreciated.
      Lee.
