Farqui
GS 450H my first Lexus
On 14/08/2017 at 1:50 PM, dougie175 said:
 Scary expensive! About the cost of my first couple of cars values added together!
This is the next step after prams. The LEXX TRIKE.
https://www.amazon.co.uk/Premium-Lexx-Trike-Tricycle-Inflatable/dp/B01N8Q389E/ref=sr_1_18?ie=UTF8&qid=1489603782&sr=8-18&keywords=Lexus&tag=autoclubinte-21
Bod
On 8/14/2017 at 11:20 AM, Farqui said:
Had pals visit for the weekend and their pah tagged along who was keen to go for a ride in the GS :thumbup1:
He has a mobility scooter which none of us thought would fit in the boot but to our amazement it went in quite easily!
Anything we bought whilst we were out, had to go inside the cabin tho :tongue:
Excuse the dirty car, I washed it the next day...honest. Along with their car which took some cleaning and machine polishing to get the Seagull poop off the roof, I've never seen such a mess :surprise:
seagulls dont get me started with bl---y seagulls
@Goldberg, wow check out the roof :ohmy:
Imagine that condensed over a few years with only occasional washes and no wax/sealant to act as a barrier.  It had eaten well into the lacquer :unsure:
In hilly Derbyshire today (Battery max'd on the downhills) I reminded myself how good the Power setting is Hills are effortless on this mode vs Normal.
I left it on all the way home, back to the flat lands of East Anglia (almost) and mpg's weren't much lower.
Which then made me wonder...if folks find the Power or Sport modes dramatically affect their mpg? Provided they drive 'fairly' sensibly...
I'm guessing its more than just the gearing ratios on your car unlike the IS250 but I always leave my IS in "PWR" mode its a much better drive in my opinion with no negative effects on fuel economy as long as I drive the same as with PWR off
Yes I agree, the pickup is earlier and feels more natural.
What I also noticed is that the brakes are sharper in PWR. So much so, that I've needed to relearn when and how much pressure is needed. I guess the Hybrid brakes are 'keener' in the higher power settings...I defo see more 'E' blocks on the Energy menu.
Yeah there is obviously no difference in the brakes on the IS but can completely understand why they would be different on the hybrid, basically the was I would describe the PWR button is that it just suits the way I like to drive
Over the 6 months+ I've owned the car the sat nav has always orientated the map to the North.
It took me a while to adjust but I've since learned the live with it.
My previous car had the setting as 'heading up', which made more sense to us.
Last weekend mrsF stops gawping out of the window and starts moaning about the sat nav orientation.
You know the sort of thing, 'thats no good', 'I can't understand where we are' or 'which way to go?', etc, etc.
I shrug, drive on and tune out...as normal :biggrin:
Then she simply presses the North symbol (top left) and boom the display now shows 'heading up'!
:ohmy:
I'm kinda embarrassed that I hadn't already tried that myself.
Worse still, mrsF now thinks she's a tech whiz!...and she won't let me forget it #sigh
She forgets that the true 'tech whiz' crown is still owned by our almost 4 year old grand daughter.
Maybe this post will save you the pain that could be saved by *ahem* prodding it.
PS: who reads manuals anyway :tongue_smilie:
Whilst trying out some scaffold boards under my jack/stands at the weekend (gravel drive) I decided to clean up the OSR arch/suspension before slapping on a good coat of rust converter.  I applied some to the tired rear disk bells earlier this year, didn't coat them with anything else and they've stayed nicely protected.  I hope to get all of the undercarriage cleaned, treated and under sealed before too long.
Anyhoo whilst I was rummaging around the OSR tail pipe I found that a heat shield fixing had corroded through. I managed to remove the nut and add a penny washer back only to find a second fixing had also failed but in a more awkward position on top of the rear box.  This nut wouldn't budge but still had enough thread for me to add a spacer and washer which nipped up the heat shield properly.
A bonus of this find/fix is that the rattle I thought was the rear parcel shelf/boot has now gone :thumbup:
  • Like 6
The GS just sailed thru it's MOT, it's first under my tenure
Corrosion on the rear disks noted but not adversely affecting braking. I have new disks and pads to go on all round once I pluck up the courage to defy the brake by wire system.
Oh and so what were Lexus trying on 8 months ago saying I needed new shox's (leaking apparently). Nothing flagged today by the indi, nor by my local mechanic or by me after several look-see's. Shox's and sticky calipers seem to be standard 'offerings' from the 'stealers'. Think I'm still bitter for them trying it on. Helps to pay for the complimentary coffee tho I guess. As the brand is relatively reliable, maybe they have to quote for unecessary work?
In a side note - Pagid Discs are coated so the top hats do not rust - these front discs have been on my 430 for over a year and look as good as new.
I plan to change the rear ones aswell
Mark @cruisermark, it's good to know that some replacements come with coated bells and yours still look dandy after 12 months use :thumbup:
Nice build thread Lee.
Have you done anything recently to your car ?
You gotta watch them stealers, always trying it on !
@SpeedyGee, thanks. Alas no other than wash it...occasionally.
Decorating is almost finished for a while tho, thankfully.
Since my brakes passed the MOT I'll park that upgrade. The wife's V-dub is in more need of some TLC next.
  • Similar Content
    • By carnut1980
      Hello.
      My 2007 gs450h makes a metallic knocking sound from the front brakes. It is more prominent when I move forward slowly,  then brake, then reverse slowly,  then brake,  etc, as opposed to during general driving at speed.
      It doesn't sound like worn bushes.  It has a higher metallic pitch.
      Front pads and discs are new. But the sound was there before I changed them anyway.
      Please see attached video and have a listen. It's driving me nuts.
      Cheers
      20170904_133321.mp4
    • By Stevebrooks
      I have followed all the other suggestions on this sight and others regarding disabling the annoying seatbelt warning gong, but no luck. I have a Gs450h and most of the suggestions are for iS and earlier GS models. Does anyone know how to disable the gong for a GS450h 2012 model?
    • By Odysseus
      I have some proper genuine Lexus mats in excellent, very clean condition in light brown/beige that were fitted my 2008 GS450H.  These were replaced by Lexus as a condition of sale as beige doesn't match the interior of my car - I got black instead.  I'm not 100% sure, but I'm sure they will fit any other GS from 2005 to 2011.
      I would like to swap for some similarly clean and tidy Lexus mats for a GS, but in light grey (my interior is Sussex Grey).
      Thanks!
    • By Keleko
      Evening,
      I've got a 2012 GS450h F-Sport and I have to pull the boot lid pretty hard to close it, should it have a soft close boot like my 2008 GS450h did?
