Lexus cluster is not working no lights no movement
Sunny649
Hi i woke up this morning and try to start the car.found out Battery was dead.jump start it everything is working except the cluster.there are no lights no movement in the needles. Checked all the fuses from interior fuse box.dont know where to start. Signal light turns on and off but that is all on the cluster.please help
I found out it was some fuse under the hood .i switched around all the fuses and the light came back on and it started working again.not sure which one was it specifically.thanks
