RCF Spare Wheel
I have just bought my RCF which comes without spare wheel. Rightly or wrongly I am uncomfortable with this.
I have read elsewhere that the appropriate skinny spare to get is T155/70d 17 although apparently one has to be careful as many of this size will not clear the front brake calipers. The spare fitted to the Toyota Supra Twin Turbo is recommended as it is said that this has a large enough dish to clear the calipers.
I have purchased such a wheel from a breakers yard which I have not yet tried on the car. Before I do I was wondering if any members have experience of this wheel and whether it will be necessary to use a spacer.
I should be grateful for any advice.
On 27/08/2017 at 8:40 PM, MNMJ said:
Yes please; do try it and let us know. I don't like driving without a spare either.
Yep me too, just jumped from an IS F with a space saver to RC F with a can of glue and a pump............         would much prefer to have an actual spare so would be good to know if the one you've sourced fits.
Yes I have seen these pictures too. The kit is not available in the UK and the boot space reduction will not be acceptable to most people.
It also seems like overkill bearing in mind that the spare would only be used to get home or to a tyre dealer and that we would be driving VERY slowly.
The best bet so far seems to be a BMW or Audi 19" steel space saver with an adaptor to convert from 120 to 114 stud spacing. This spare would probably fit under the standard boot floor.
I wonder if any member has tried this?
I had a Focus Rs for a while no spare just gunk, like others I won't run without a spare, I got it all from Ford not cheap Wheel, jack brace, tyre and a different boot mat/trim.
Some 10 months later Christmas Eve early evening just got over the Humber bridge and a large bolt through the rear n/s tyre, could have ruined our Christmas break without the spacesaver, the size tyre needed was not available anywhere.
They in my mind are worth there weight in gold 😏
As always you never know......
Big Rat
I have reluctantly concluded that a skinny spare is not possible due to the size of the front discs on the RCF. The spare wheel must be 19".
Safety issues are obviously paramount and the Audi wheel and adaptor sounds a bit "iffy" plus the fact that an adaptor is likely to cost a lot more than the wheel itself.
I have just purchased a full sized used Lexus wheel, size 235/40 19 and I will see what I can do with this. The recommended spare is 225/40 and I guess that I could change the tyre on my full sized spare to gain a bit of storage space, but this hardly seems worth it
The pictures submitted by Big Rat signal a possible way forward and I may construct a similar boot floor from plywood and car carpet.
I guess the only other alternative is to take the full sized spare in the boot when I don't need the space for other things and otherwise rely on my bottle of Slime and pump!
My AA membership, courtesy of Lexus, is a last resort.
I have now purchased a used, but like new, Lexus 19" wheel tyre size 235/40. This is slightly larger than the 225 size which Lexus fit as this seems to be unavailable or hard to get.
The wheel fits easily in the boot and only sticks up by 3" above the floor level.
The next step is to construct a new carpeted boot floor with a raised area similar to Big Rat's post.
I will report again in due course.
In the meantime I wonder if any member is aware of the bolt size and thread for the centre fixing bolt?
Something I just read. The tyre sealant lexus put in the boot destroys the tyre pressure sensor. Expensive puncture repair that! Have for now got a puncture repair kit - the type you fill the hole with a rubber strip.
I would assume same problem exists with holts Tyre Weld etc if Tyre sensors are fitted.
Here is my take on a spare wheel for the Lexus RCF. Everything can be reversed to "as was".
The problem is, of course, the large front brake discs and calipers. To accommodate these a 19” wheel is required and this has to be at least 8.5J or, as in my case, 8.0J with a 5mm spacer. This will not fit under the existing boot floor so a new floor is required. This consists of two shaped pieces made from 18mm plywood.
The standard Lexus wheel nuts allow 7 or 8 turns even with a 5mm spacer so this seems to satisfy safety aspects and using the spacer gives around 7mm clearance to the front calipers.
All the parts supplied with the car, the foam boot floor insert, the hard flat unit accomodating some tools and the carpet boot floor have been preserved.
A 235/40 tyre on a Lexus 8J x 19 alloy wheel with +45 offset is fixed to the boot floor using an M8 threaded rod, with the outside of the wheel facing upwards.
A new boot carpet made from two thicknesses of car carpet glued together for greater strength is provided.
The wheel protrudes above the standard boot floor level by about 3 inches and until I can think of something better it is covered by a vinyl cover.
Having just jumped from an IS F to the RC F I am also not to happy with the lack of spare wheel and this looks like a good solution. Not sure my diy skills are as good as yours though with making the cut outs and carpeting!
Yours looks pretty professional though.
Where did you source the wheel from?
