AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
I am thinking about getting a dashcam for my IS250 (3rd gen) but am amazed at the variety am finding it difficult to settle on a particular make/model. I am looking for a mid-range model (£60 - 120 but not fixed on this) that does not need to be hard-wired in. However, I don't like the idea of a lead dangling down so, ideally, would like one that runs just on an internal re-chargeable battery. That said, it needs to be easily and quickly removed from its mounting point both for re-charging and for security when the car is not in use. If a stand-alone model is not available, then I would like it to be connected to the USB socket rather than cigarette lighter one. Any recommendations would be welcomed. Similar posts by others in this forum have included recommendations but the models seem to be no longer available.
I bought the Transcend drive pro 200, had it about 4 years and I can't fault it.  Small, excellent image.  I just push the wire around and under the trim and plug it in a 12v socket/lighter.  The only important thing is to buy the optional windscreen sucker as the one it comes with is rubbish.  I think it's about £80 or so.  Personally I can't see how you could get much better for the money but I'm sure others will disagree!
Very many thanks for your quick response, The-Acre. I will have a look at that model. They are on amazon at £119 but that's not out of the question.
Viofo A119, different form factor to most, doesn't rely on a suction mount, they always fall off eventually (or in a shunt if you watch the YouTube east european wrecking vids!) Mine came from here there, although there now appears to be a newer version with an updated GPS mine has never had a problem getting a lock. One of the few cameras to fully support 64gB cards.
I couldn't quite get it behind the mirror on the offside as I have my mirror quite low which swings it forward, as you can see the installation is particularly inconspicuous. The GPS receiver (which has the USB socket at the top) is actually stuck to the dotted part of the screen with double sided tape and the camera simply slides on to the GPS. The supplied is tucked away in the edge of the headlining and down the nearside A pillar. A hardwire kit is also available.
Nearly forgot, it doesn't rely on a cheap lithium battery (not so good when they're full in the sun!) but has a couple of large capacitors to enable it to shutdown and save the last video.
YouTube video here, actual quality is somewhat better before youtube squashes it......
Regards
Andrew
Edited by C Andrew Green
Forgot a couple of points....
Thank you, Andrew. The Viofo A119 certainly seems to have some good features at a reasonable price. It is now on my short-list.
I have a Next Base 312GW fitted by Halfords, hard wired and total cost £130. Without hard wiring, he unit is around £80. Works very well and when replayed shows where the car is at any given time, and what speed as well as recording events. Very useful when your car is left at an airport parking service or when anyone else is driving your car.
i have a Nextbase 402G fitted to my RX and i managed to hide it behind the rear view mirror, you can also turn the screen and sound off so you completely forget its there.Obviousley the driver returning my car from service a while back didn't notice it, as he was doing upto 84mph on 60mph roads which i thought was quite unprofessional.
The mechanic who serviced it and then took it on its test drive however kept to the speed limits which was nice to see even though i'm sure he clocked the dash cam.
The playback colour footage is of good quality too.
Many thanks to all those who responded to my query - you have provided me with reliable recommendations and plenty of good food for thought.
  • Similar Content
    • By C Andrew Green
      I'm planning to hardwire my Viofo A119 dashcam (as it came with a hardwire kit) and hoping to put the adaptor in the dome light housing.
      Does anyone have a wiring diagram that shows the dome light wiring? I had a poke around the dome light connector (both side pictured below) with a meter at lunchtime but it was somewhat inconclusive...... I found a permanent 12V but couldn't find an additional feed that was alive with the ignition....
      Anyone else done this?
      Regards,
      Andrew
    • By Hardy
      Hi, Has anyone hard wired a dash cam mounted by rear view mirror on windscreen?
      Maybe get a feed from interior lights by rear view mirror?
    • By bhardman
      Hi, I am contemplating purchasing a dashcam and will want to hardwire this in. Can anyone recommend a camera and has anyone hard wired in 300h SE?? if so how??
    • By TwitchyArmadillo
      Hi
      Apologies to Capitalmagie for posting a similar thread to his own.  I feel the need for a dashcam but am wondering if Lexus recommend a specific dashcam or whether the fit a specific one?  I'm trying to avoid having wires all over my central column and don't like the idea of anything suckered to the windscreen.  Does anyone have any good alternatives?
