WilliamH
Replacement battery from Eurocarparts doesn't fit
Had to get a replacement Battery in a hurry today for my 2003 IS 300 Sportcross, so went on-line.
Eurocarparts website was easy to use and had a tasty discount offer. They had a choice of 2 so I selected the more expensive one with 70Ah, CCA 540A, rating and ordered it 'click and collect'. £67.40 inc vat and 3 year g'tee which I didn't think was bad.
Now I've got it home I can see it doesn't fit the Battery tray properly. The base area is too big to fit deep in the tray so it sits quite high. Also, the new Battery is 10mm taller than my knackered Battery. As a result, the standard Battery clamp won't fit (the rods aren't long enough) and the terminals are worryingly close to the closed bonnet.
Is this a common issue?
Is there a work around or will I have to return it to eurocarparts?
Is there a generally recommended/ easily available Battery that fits?
Thanks in advance for your replies!
Return the Battery to Eurocarparts as it clearly is not the correct fitment. Not only does it pose a fire risk from shorting out on the bonnet, but is also an MOT failure being not fastened down.
I must admit many Battery suppliers list the wrong batteries for various cars. I had the same problem when looking for a Battery for my Prius. Halfords tried to fit a Battery with not only the wrong type of posts, but also orientated so that the positive terminal could easily short circuit to the car body "the Battery being in the boot".
John.
Thanks John. I hadn't even considered the MOT failure aspect. I'll take it back tomorrow.
I had a 'wrongun' from ECP for an MX5 a few years ago. To their credit ECP changed it without question. Only bind was having to go back to store to get it swapped.
I find you do have to double check approved fitments from just about anywhere as some details that are accessed in good faith by these companies are sometimes proved to be wrong. I generally go armed with what I know to be the correct detail now. Last weekend Halfords tried to sell me any old coolant, despite asking for 'FL22' type for wifeys newer MX5. Their booklet said they were right ...they weren't.
@normski2Wise words - thanks.
I was disappointed that the Lexus owners manual doesn't give maximum Battery dimensions nor recommended Battery capacity/ performance. I felt I didn't have much choice but to accept the ECP recommendation.
  • Similar Content
    • By sannyp
      Hello,
      So I recently got into a little accident with my is200 manual and now need a new rear hub, and maybe other parts although unsure what yet. Question is will parts from a is200 auto suffice. So I wanted this post to outline the differences.
      I know the differential is different with a higher ratio i believe, and obviously the tranny. But is there anything else?
      I have a guy ready to sell me a bunch of parts from an auto is200, but I'm sceptical with mine being a manual
      thanks
    • By Shyamal IS300H-FSPORT
      Hi all,
      I have recently bought a Lexus IS300h F port and I was told to get a tracker fitted by one of my colleages. I have bought the tracker that was suggested to me but I have no idea where or how to fit it.
      The instruction manual says to attach it to a 12-36V charger (I'm assuming the 12V Battery in the boot). I have never done anything of this sort before so I just wanted to ask
      a) is it safe for me to try and fit the two leads myself?
      b) would me attaching a tracker to the 12V Battery drain it & cause problems??
      Hope to hear from someone soon..
      Shyamal
      Ps: the picture below shows the two leads that I'm supposed to connect to the Battery if it makes sense to anyone
    • By Arqum
      Hello peeps. So my replacement Battery i had was a Toyota Optifit which tbh im not happy with. Been 18months and its struggling as the days get colder. I bought a Ctek charger which charged it and it was ok for a day and then when i measured it across the terminals i was only getting 11.8v
      Can someone who has the original factory fitted Battery take a pic for me and if they can find out the spec and part number from the Battery please?
      Cheers
    • By Nickyt211
      Hello this is just a question out of curiosity, I've cleaned and polished my new rx300 2004 plate I've had it 2 weeks now and I believe it's running on it's original Battery it looks a bit old tbf, it's a Panasonic Battery and it says distributed by Toyota on it. It can't surely have lasted this long can it? Lol
      My question is which Battery do you guys think would be up to the job, which brand do you recommend. Just interested in makes and models etc. Thanks
    • By J Henderson
      Having a much-needed clearout. Collection from EH51, or can arrange postage at buyer's expense.
      IS200 "Sport" Chrome Tailpipe
      Hard to find genuine item in very good condition. The underside a little pitted but not visible once fitted. Adds a touch of class to any IS200/300 with a stock exhaust system. £20
      IS200 Drive Belts
      Full set of Gates drive belts for 1G-FE engine cars - Power-steering, Air-con & Alternator. Brand New, never fitted. £20
      HB4/9600 OSRAM Fog Breaker Bulbs
      Colour temperature approx 2600K (Yellow). Brand-new & sealed. Will fit front fogs on '99-'03 1st Gen IS or '05-10 2nd-Gen IS (and possibly others..). £20
