Anyone know if its an easy process to take the two jets off in order to clean out - the drivers side on mine is still working but only sprays through half of the jet. Have had a quick look and it looks like the bonnet noise insulation needs to come off first?
Can't say I have ever done it personally, but in case you haven't seen it, the manual says the following:
Interestingly, if I am reading this right, you can get different nozzles to help you aim the stream.  First time I have seen such a thing.
