Lexus NX300h Fsport Internal fuse box for UK model
Hi guys,
Just got my NX on the 1st September so new to this forum so hello everyone!
Im looking to install a Dash come however having it powered directly through the fusebox. I have seen a video on your tube which shows the fusebox located under the glove box however based on that video and what i see under my car is different.
Can you confirm on the picture i have attached that i need to take that cover off that is located below the glove box. If this is the case, any ideas how too?
Thanks In advanced
It's the panel just above the passengers feet, you can unclip it at the back edge then slide it backwards a bit to remove it completely after disconnecting the footwell lamp. There isn't much room in that area, but you should be able to tap into the correct feeds, on all the time and on with ignition if you're using something like the power magic pro.
Thank you for your response.
Just to confirm the plastic cover in the pic that is surrounding the light shown needs to be removed In order to see the fuse box?
  • 3 years later...
I wish to install the Blackvue 750s 2ch dash cam with the Power magic Pro----
Where & which are the best fuse slots available to achieve this.
Kind Regards
Bob
 I need a constant fused power source slot also a switched fused slot (Max devices output current 2A)
